Old 11-30-2016, 12:16 PM   #1
Bluesman62
Bluesman62's Avatar
Drives: 2013 Subaru BRZ Premium
Reading Tire Pressures Real Time via TPMS Sensors
My new 2017 Kia Sportage will actually display in real time (or close to it) the pressure of each tire via a display on in the gauge cluster. Assuming that works off of the TPMS. Very cool feature.
Would love to be able to read the tire pressures in real time in my BRZ rather then just having an idiot light in the dash. Besides the reprogramming and hand tools which would not do you good while actually driving, does anyone know of a system that can read the TPMS sensors or plug into the OBD2 port to display that info in real time?
The only thing I found are those systems which have the sensors in the value stem caps and has a display that plugs into 12V port.
Bluesman62 is offline   Reply With Quote
Old 11-30-2016, 12:24 PM   #2
Cole
Not a troll
Cole's Avatar
I believe @Shiv@Openflash was working on it, but I haven't seen any actual progress on it yet. But then again, I'm not following that too closely. Torque may be able to do it?
Old 11-30-2016, 01:45 PM   #3
JDM4E
Drives: Honda Accord Euro
I like that feature too. Subscribed.
I think that perhaps changing the sensors will be needed. There quite a lot aftermarket systems available, they even can monitor the air temperature which is great I think and it is the way I would go.
JDM4E is offline   Reply With Quote
Old 11-30-2016, 02:20 PM   #4
Bluesman62
Bluesman62's Avatar
Ours do. I was just at the dealer to have the sensors in my wheels registered with my car (long story! The Story )
While the tech was doing it he showed me all the parameters the sensors were sending to the car which included temperature. Has was using a (very expensive I assume) Snap-On programmer to check everything.
Old 11-30-2016, 05:34 PM   #5
JDM4E
Great info. Now the harder bit - how to read that data in a car
Old 12-01-2016, 12:24 PM   #6
sirsol66
Drives: 2013 FRS- Hot Lava
Your TPMS sensors send a data packet every 10 seconds or so when they see motion. As mentioned, they send temperature, movement (yes or no), and individual pressure. We lack the secondary ECU for autolocation so they dont know where on the vehicle they are. Everything goes through the CANBUS setup so getting the reading shouldnt be difficult honestly. It just comes down to programming OFT or something to actually pull that information.
You can see all that information with tech stream (non lite) or similar equipment.
sirsol66 is offline   Reply With Quote
Old 12-01-2016, 12:47 PM   #7
Icecreamtruk
Drives: Track preped NA FRS
Can it be possible to read it out thru torque if we know where they are being transmitted (custom PIDs in torque)?
Old 12-01-2016, 12:51 PM   #8
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
@Shiv@Openflash
Originally Posted by humfrz
I'm old and lazy
Old 03-08-2018, 08:07 AM   #9
iamrich83
Drives: 2017 Toyota 86, 2000 Mazda Miata
Has there been any progress on this? I tried searching...
iamrich83 is offline   Reply With Quote
Old 03-08-2018, 11:11 AM   #10
Racecomp Engineering
I thought about this a while back. Sounds like a project for a RaspberryPi or Arduino pro (which I am not).
- Andrew
Old 06-09-2021, 04:29 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by ermax View Post
Current gen has pressure and temps via CANbus but I’ve never found a way to read them. Techstream can read them so I know it’s possible.
If anyone found the CAN or OBD-II PIDs for tire pressures and temps, let me know!
timurrrr is offline   Reply With Quote
Old 06-09-2021, 04:49 PM   #12
gpvecchi
gpvecchi's Avatar
Techstream reads tires pressure, so this data is accessible by OBD.
gpvecchi is offline   Reply With Quote
Old 06-09-2021, 07:40 PM   #13
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
A ScanGauge can read tire pressure and temperature from the OBD port. It only updates every 3 to 5 minutes but I don't know how often the TPMS sensors actually report data. But how often do you realistically need an update?
Here's a thread with more from 2013:
https://www.ft86club.com/forums/showthread.php?t=28374
And an update from 2018:
https://www.ft86club.com/forums/showthread.php?t=128103
LimitedSlip is offline   Reply With Quote
Old 06-09-2021, 08:40 PM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
NICE, thanks for digging this up!
So if I'm reading https://www.scangauge.com/toyota-tpms-method-2/ correctly,
the bytes that get sent over the CAN bus for the request are 0x07502A2190.
I'll need to spend some time trying to figure out how to enter it into e.g. RaceChrono.
Dang, I just swapped took my daily wheels with TPMS off the car and put AutoX wheels on, now I can't wait to swap back.
I know that for fuel level the RaceChrono setup is
Channel: Fuel level (L)
OBD-II header: 0x7C0
PID: 0x2129
Equation: A/2
Here's the ScanGauge setup for the same data:
Originally Posted by pkny View Post
Working code for FR-S/BRZ/86:
Code:
Gauge                          Unit           TXD                  RXF                      RXD      MTH                      Note
Precise Fuel Level         %         07C02129       046105290000     2808    000100010000    Faster refresh rate
07C02129 looks like 0x07C0 + 0x2129.
So 0x07502A2190 could be something like
OBD-II header: 0x750
PID: 0x2A2190
Also will need to read ScanGauge manuals on what all those RXF/RXD/MTH codes mean, so that we can figure out what scale/offset to use.
If somebody figures it out before me, we will all appreciate if you post your findings here
New TPMS Sensors - Car Not Reading Them Bluesman62 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-27-2016 01:41 AM
SOLD - Set of 315MHz TPMS - $125 OBO - Tire Pressure Sensors badamowski Wheels and Tires 0 07-16-2014 10:07 PM
Tire Pressures mike the snake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-21-2014 04:03 PM
Tire Rack tpms sensors TimR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-27-2013 12:12 PM
WTB: Tire Pressure Monitoring Sensors (TPMS) RYU Wheels and Tires 6 09-18-2012 12:52 PM
