Old 11-22-2016, 06:29 PM   #1
qqzj
Drives: MDX, Camry
The best RPM or technique to shift from 1 to 2?
I have been doing this for a long time (>3 year), but I still cannot figure out the trick. Every time I shift from 1 to 2, I can feel/hear a clunk or a hesitate. Sometimes I have to double clutch to 2nd to have a peace of mind. So any techniques I can learn here?
(Sometimes when the car is fully warm and I can shift w/o a clunk, starting at about 2800-3000 rpm. But that scenario is rare. I am more concerned about the first several shifts every morning.)
Thanks!
qqzj is offline   Reply With Quote
Old 11-22-2016, 06:44 PM   #2
BRZbliss
BRZbliss's Avatar
Drives: 2014 BRZ
I'm guessing that you're shifting a bit on the fast side as if you're racing. I think it's okay to ease in and out of the clutch a bit slower for a smoother transition. (I've been driving stick for about 20 years now)
BRZbliss is offline   Reply With Quote
Old 11-22-2016, 07:24 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
The only time you should shift from 1st to 2nd is at 7400RPM, any other time and your just plain doing it wrong.
The Following 6 Users Say Thank You to go_a_way1 For This Useful Post:
Apoc (11-23-2016), Chronology (12-09-2016), jarnojvv (12-13-2016), Luftwaffel (11-22-2016), Stang70Fastback (12-06-2016), ToySub1946 (11-22-2016)
Old 11-22-2016, 07:29 PM   #4
gramicci101
Off Topic
Here, from another thread. First to second has the largest change in RPM for any given speed, so it'll take longer for the RPM to drop. Also, these transmissions are notorious for being difficult when cold.
Old 11-22-2016, 07:30 PM   #5
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Just tap the right hand paddle whenever you want to - shifts like butta.
geezerbrzeezer is offline   Reply With Quote
The Following 3 Users Say Thank You to geezerbrzeezer For This Useful Post:
Cole (12-10-2016), finch1750 (12-10-2016), go_a_way1 (11-23-2016)
Old 11-22-2016, 07:42 PM   #6
that_one_guy
Drives: none
Originally Posted by gramicci101 View Post
No wonder those automatics are blasting by me in 5th going 180mph while I'm maxed at 172!
that_one_guy is offline   Reply With Quote
Old 11-22-2016, 08:09 PM   #7
ryoma
ryoma's Avatar
I usually wait for the RPM's to drop while slowly releasing the clutch. it's probably about a 1.5 second wait from clutch in to clutch out when shifting from 1st to 2nd. you'll get used to it after experimenting a little. sometimes I still mess up and it's jerky though. the 1st to 2nd shift is probably one of the things I dislike about the car.
Old 11-22-2016, 09:33 PM   #8
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
Had the same problem in my Chrysler Crossfire. Just start out in second.
winstonscifi is offline   Reply With Quote
The Following User Says Thank You to winstonscifi For This Useful Post:
vintagemxer (11-22-2016)
Old 11-22-2016, 09:50 PM   #9
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
vintagemxer is offline   Reply With Quote
Old 11-22-2016, 09:59 PM   #10
track junkie
Drives: 2022 Subaru BRZ
Thanks!
Join the club. I shift from 1 to 3 until the engine has warmed up. I won't even try shifting from 1 to 2, if the engine hasn't warmed up, since there is no technique that will result in a smooth shift to 2nd while cold. When the engine is warm shifting from 1 to 2 is very smooth.
It is just a characteristic of our gearbox that we accept. http://www.ft86club.com/forums/showp...71&postcount=1
track junkie is offline   Reply With Quote
Old 11-22-2016, 11:36 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Thanks!
I've written on this many times. There are a couple things to consider.
1. When it's cold the gear oil is like molasses. With the clutch disengaged and shifted to neutral, everything in there grinds to a screeching halt.
2. The syncros aren't super grabby.
So, with those in mind, the 1-2 shift more than others is about being quick. Just don't pause at all in neutral. Get right on that second gear syncro before the gears have time to stall.
If you miss, you're already doing the right thing with double clutching. You're just spinning up the gears and going for a second try.
The clunk is going to happen. Nothing wrong with it.
Old 11-23-2016, 09:25 AM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Old 11-23-2016, 09:45 AM   #13
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
CVT swap. No more problems.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 11-25-2016, 06:44 PM   #14
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I wonder if maybe this is more of an early model issue. I've never had issues going 1st to 2nd after i cold start in the morning. And lately we've been hitting temps of 30 degrees here in Nor Cal. Granted its nowhere near as cold as places that snow so maybe thats the difference?
Edit: NVM just checked OP's location and he's in the city where its actually warmer. /shrug
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
2-Bucket Wash Technique imravenit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 01-09-2014 12:39 AM
Taniguchi shows basic technique m.box.design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 10-25-2013 10:47 PM
Driving Technique - Track Out DarkSunrise Tracking / Autocross / HPDE / Drifting 23 10-15-2013 05:42 PM
Driving: Technique cgrey Tracking / Autocross / HPDE / Drifting 2 01-15-2013 09:38 AM
