Old 07-22-2012, 09:29 PM   #1
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
2-Bucket Wash Technique
so whos here uses this technique? is it worth investing on the tools and equipments? thanks for your advice!
imravenit is offline   Reply With Quote
Old 07-22-2012, 09:47 PM   #2
encity5
encity5's Avatar
I do. Yes its worth investing, helps better avoid swirlmarks.
encity5 is offline   Reply With Quote
The Following User Says Thank You to encity5 For This Useful Post:
Hamza7 (01-11-2014)
Old 07-22-2012, 09:58 PM   #3
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
so you actually follow the process?
rinse..
foam..
wash..
pooling water..
air blower..
etc?
if so any suggestions how to save $$$ on investing on these products/items? where to buy etc?
Old 07-22-2012, 10:00 PM   #4
#87
I usually post drunk
#87's Avatar
Find good products and buy the large quantities, many are sold in gallons and wait for sales such as % off all purchases or free shipping since they weigh a lot. autogeek.net you can try
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
imravenit (07-22-2012)
Old 07-22-2012, 11:40 PM   #5
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
IMO, the two bucket wash methond is the only wash method.
Get the 5 gallon buckets at Home Depot, theyre pretty cheap. Search online for Grit Gaurds. And as previous mentioned, buy your products in bulk. Thats the cheapest way. For example:
A 17oz bottle of Optimum Spray Detailer and Gloss Enhancer is ~$10. A 128oz jug of the concentrated spray detailer is $60. Since its concentrated, you use a 4:1 mixture (water:product). That ends up being 512oz for $60. You'd get 1/5th that amount for the same price if you bought the regular spray bottles.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 2 Users Say Thank You to civicdrivr For This Useful Post:
Bonburner (07-22-2012), imravenit (07-22-2012)
Old 07-22-2012, 11:44 PM   #6
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Ya ive been looking around autogeek.net
Old 07-22-2012, 11:46 PM   #7
CU2MIKE
Drives: Nissan Altima, plan to get a FRS
Amen to that!
CU2MIKE is offline   Reply With Quote
The Following User Says Thank You to CU2MIKE For This Useful Post:
civicdrivr (07-22-2012)
Old 07-22-2012, 11:48 PM   #8
_hollywood
Drives: 97 itr sold
The grit guard is key for the 2 bucket method, also wash top to bottom and i use a seperate microfiber sponge for the lower areas of the car, and always keep the paint wet and soaped up.
black cars are ftw, and then 1 hour later ftl
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
The Following 4 Users Say Thank You to _hollywood For This Useful Post:
Bonburner (07-22-2012), civicdrivr (07-22-2012), imravenit (07-22-2012), trifenix (07-23-2012)
Old 07-22-2012, 11:53 PM   #9
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
thanks everyone!
Old 07-23-2012, 01:31 AM   #10
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
I definitely recommend it. You will avoid swirls and have your car sparkling shine, only downside will be when you hit a puddle or something like that and you will be pissed your hard work was for nothing lol.
Ill share with you my process and hope it helps.
-First get your self some good quality soap that produces lots of suds. I recommend chemical guys, Detailers Pro Xtreme, XMT, best over the counter soap i have found is ZYMOL at autozone.
-Get your self a nice microfiber sponge or wash mit auto geek has tons of options
-Leaf Blower or microfiber to dry both work of course the leaf blower will avoid more swirls.
-Two buckets with grit guards, i bought the chemical guys ones but autogeek has some as well.
-Pressure washer and foam cannon are optional but they do a great job in getting the rough stuff loose for ya!
Ok here is my process.
1- I start off by giving the car a light spray of water in the wheels and spray chemical guys diablo wheel cleaner. I let it sit for about 2 mins and then start scrubbing the wheels with the chemical guys gerbil, i like it because you dont only clean the face but you get the inside of the wheel as well. Once all 4 corners are scrubbed i spray the wheels with water again.
2- I pressure wash the car keeping the nozzle at a safe distance and even getting under the car to keep the under carriage clean. I make sure to cover the whole car with enough water so i have no dry spots.
3- I connect my foam cannon to my pressure washer filled with soap, and i spray the whole car since this will create another layer of suds between your wash mitt and your paint.
4- Having foam still on the car i dip my wash mitt into the bucket i have filled with soap and start cleaning it from the top first working my way down to the bottom try cleaning your mitt often by rinsing it in the clean water bucket make sure to scrub your mitt on the grit guard to make sure all the debris stays in the dirty water bucket. Dip in the soap bucket and repeat the process all over the car.
5- I will then rinse the car with clean water and proceed to the drying stage.
6- Leaf blower is the best choice but if not dry it with a microfiber dragging it from once side to the other but not going back and forth try to dry it in one pass and divide your car in sections, always start from the top just in case there is a bit of dirt still in the lower part that could potentially scratch your top body panels which are the most visible. BTW try to try your car inside your garage to avoid any dust particles getting on the paint while you dry it.
7- Make sure to dry your wheels with a separate microfiber.
8-At the end if you want to make it shine some more apply some paint gloss enhancer i recommend the chemical guys one which smells awesome btw.
Here are some pics of my process.
Here are my two buckets i labeled one with a D for Dirty so i dont confuse my self.
Foam Cannoned
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 4 Users Say Thank You to track_warrior For This Useful Post:
blue cat (05-25-2013), djdnz (07-23-2012), imravenit (07-23-2012), mxrcmxlendon (06-02-2014)
Old 07-23-2012, 03:03 AM   #11
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
pcasso for the save!
For me the foam cannon things eliminated my need for the 2 bucket system. Now I just use a foam cannon and a 2 mitt system.
I gotta ask though, why would you leave the tow hook out like that? Are you meeting some racing regulation that states you have to have one in case the safety truck needs to tow you back into the paddock?
Old 07-23-2012, 04:06 AM   #12
wallace03
wallace03's Avatar
Drives: WRB BRZ
i think the tow hook looks cool. why do you use two mitts?
wallace03 is offline   Reply With Quote
Old 07-23-2012, 04:10 AM   #13
#87
#87's Avatar
because race car
http://www.ft86club.com/forums/showthread.php?t=11391
Old 07-23-2012, 09:23 AM   #14
BR33Z3
BR33Z3's Avatar
Drives: 2013 WRB BRZ
When I use my leafblower to dry the car, I always end up with some water spots (b/c of hard water in my area). Anyone have any advice??
BR33Z3 is offline   Reply With Quote
Whats your Bucket List (Car Washing) ? imravenit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 07-26-2012 12:29 AM
Help in wash and detailing WHITEOUT FRS.. tintumz22 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-16-2012 09:37 AM
How often do you wash your FR-S? terrypm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 50 07-14-2012 03:24 AM
How Do You Wash Your Car? Xiao Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 86 06-09-2012 07:11 PM
Aero Design Bucket seats CyberFormula Off-Topic Lounge [WARNING: NO POLITICS] 2 08-15-2011 06:49 AM
