Drives: 2015 Scion FR-S
Warning Light?
Does anyone know what this light means? I dont have the owners manual for the car. I have a feeling it might be due to tire pressure but im not sure. Any help would be appreciated. Thanks
The Gunshine State
Drives: '14 BRZ Limited
Hint, check your tire pressure.
![]() Current DD: M235i |
Drives: 2013 Raven FR-S
great first post. welcome! as for your problem, i believe you are on your own.
#FiftyShadesOfBlue
Drives: 2015 FR-S
I think it means you have an exclamation mark stuck in one of your tires. Unfortunately the display is not advanced enough to let you know which tire. A quick visual inspection of all 4 should easily find the exclamation mark in question.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
The Gunshine State
Exclamation? I thought it was an upside-down i
Drives: on the highway to hell
#FiftyShadesOfBlue
Drives: 2015 FR-S
I think it just depends on what part of the tire it is stuck in. As soon as it rotates to the top part of the tire the display will probably change to an i
Lol thanks. I'll be sure to watch out for those exclamation points when driving now...
#10 |
I think my TPMS is defective. I haven't seen it light up once and I was way below 35psi. 28psi at one time I believe on all four tires.
There was this hot jogger chick resting near the gas station and I put in the wrong value at the air station and you know what I'm getting at here. |
#11 |
And will briefly be a Morse code A or N depending upon what side it is on during the rotation.
#12 |
Hi everybody!
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
If you don't know what that light is, you should maybe re-evaluate your choice of car.
#13 | |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
If you don't know how to not be such a ****, maybe you should reevaluate your choice of forum posting |
#14 | |
![]() Here is to hoping that is the worst light you ever see on your car's instrument panel ....... ![]() humfrz |
| Water pressure warning light | philooo | Tracking / Autocross / HPDE / Drifting | 7 | 03-01-2016 03:39 PM |
| Warning light for knock events? | mrk1 | Software Tuning | 3 | 05-24-2014 12:33 PM |
| my warning egine light is on | vinpan | Issues | Warranty | Recalls / TSB | 10 | 05-07-2013 11:44 PM |
| TPMS warning light | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 12-30-2012 08:24 PM |
| Warning light came on, what could it be? | whtchocla7e | Issues | Warranty | Recalls / TSB | 13 | 10-21-2012 04:20 PM |
