Old 11-16-2016, 01:36 PM   #1
albeezy
Drives: 2015 Scion FR-S
Warning Light?
Does anyone know what this light means? I dont have the owners manual for the car. I have a feeling it might be due to tire pressure but im not sure. Any help would be appreciated. Thanks
albeezy is offline   Reply With Quote
Old 11-16-2016, 01:36 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Hint, check your tire pressure.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-16-2016, 01:43 PM   #3
https://carmanuals2.com/get/scion-fr...s-manual-97594
Old 11-16-2016, 01:45 PM   #4
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
great first post. welcome! as for your problem, i believe you are on your own.
cdq85 is offline   Reply With Quote
Old 11-16-2016, 01:49 PM   #5
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I think it means you have an exclamation mark stuck in one of your tires. Unfortunately the display is not advanced enough to let you know which tire. A quick visual inspection of all 4 should easily find the exclamation mark in question.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 11-16-2016, 01:53 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Exclamation? I thought it was an upside-down i
Current DD: M235i
Old 11-16-2016, 01:54 PM   #7
86Boyz
Drives: on the highway to hell
86Boyz is offline   Reply With Quote
Old 11-16-2016, 01:57 PM   #8
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I think it just depends on what part of the tire it is stuck in. As soon as it rotates to the top part of the tire the display will probably change to an i
Old 11-16-2016, 02:04 PM   #9
albeezy
Lol thanks. I'll be sure to watch out for those exclamation points when driving now...
Old 11-16-2016, 02:07 PM   #10
86Boyz
I think my TPMS is defective. I haven't seen it light up once and I was way below 35psi. 28psi at one time I believe on all four tires.
There was this hot jogger chick resting near the gas station and I put in the wrong value at the air station and you know what I'm getting at here.
Old 11-16-2016, 02:07 PM   #11
And will briefly be a Morse code A or N depending upon what side it is on during the rotation.
Old 11-16-2016, 02:33 PM   #12
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
If you don't know what that light is, you should maybe re-evaluate your choice of car.
Frishkorn is offline   Reply With Quote
Old 11-16-2016, 02:39 PM   #13
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Ya he probably has a buyers remorse return policy like all other car purchases right?
If you don't know how to not be such a ****, maybe you should reevaluate your choice of forum posting
Toyarzee is offline   Reply With Quote
Old 11-16-2016, 03:48 PM   #14
Welcome to ...... The Forum .......
Here is to hoping that is the worst light you ever see on your car's instrument panel .......
Water pressure warning light philooo Tracking / Autocross / HPDE / Drifting 7 03-01-2016 03:39 PM
Warning light for knock events? mrk1 Software Tuning 3 05-24-2014 12:33 PM
my warning egine light is on vinpan Issues | Warranty | Recalls / TSB 10 05-07-2013 11:44 PM
TPMS warning light FRSowner Scion FR-S / Toyota 86 GT86 General Forum 6 12-30-2012 08:24 PM
Warning light came on, what could it be? whtchocla7e Issues | Warranty | Recalls / TSB 13 10-21-2012 04:20 PM
