Old 11-13-2016, 11:15 PM   #1
Thehark1
Drives: '13 BRZ
"Puff" of air when blipping throttle
Hey all! JUst got my 2013 BRZ a few days ago. She runs great. Had it checked over by my mechanic and he found nothing glaring. He drove it too and it all checked out.
I've been noticing that when I blip the throttle on downshifts or when I blip it in idle, there seems to be this puff of air noise that occurs a split second before the RPMs rev up. It's almost like a very quick and slight hesitation or something. Hard to describe it without actually being able to hear it in person unfortunately.
It's worth mentioning that the previous owner had a complete header back exhaust with a tune before I bought the car. When I bought the car he put a new stock header back system back on and flashed the ECU back to stock (he was running a tune with his aftermarket set up). Also, the car still has the Perrin inlet hose on it right now
The car runs great, no loss of horsepower, It feels every bit as fast, if not faster than my buddies' totally stock 13' BRZ.
Is this a cause for concern? Could the car be running lean? Really not sure what to do. Thanks!
Thehark1 is offline   Reply With Quote
Old 11-13-2016, 11:28 PM   #2
OND
OND's Avatar
Drives: 2023 BRZ
In my previous car I first recognized that sound when I installed an exhaust, it became louder when I added an intake. It's just air rushing thru intake and exhaust at sudden throttle changes.
For you its probably just the inlet hose amplifying some induction noise and you being very sensitive to all sorts of noises with the new car.
This car has multiple different sources of noise that worry some people initially, but functionally they cause no issues (transmission clunks, fuel pump chirp etc.)
OND is offline   Reply With Quote
Old 11-13-2016, 11:30 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Normal. That's the throttle butterfly opening. Imagine covering the hose on a shop vacuum then lifting your palm off of it. Same sucking sound.
Old 11-13-2016, 11:37 PM   #4
Thehark1
Drives: '13 BRZ
Thanks guys. I remember a few months back when I bought my Tacoma I was sensitive to every noise and vibration but it turns out it was all just normal.
I guess this is much the same. The previous owner told me I do not need a tune with just an inlet hose because it keeps the MAF sensor in the same place. Is this true?
I have been trying to find any threads about it online for a few days now with no luck.
Thanks again for your help
Old 11-13-2016, 11:39 PM   #5
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Does it sound something like this? Starts at ~1:15
Brzerker is offline   Reply With Quote
Old 11-13-2016, 11:40 PM   #6
Ultramaroon
not playing cards
Yeah, you're fine with just that.
Old 11-13-2016, 11:43 PM   #7
Thehark1
Drives: '13 BRZ
Yup that first little blip or hesitation is similar to what I am hearing!
Old 11-14-2016, 02:05 AM   #8
humfrz
Hey all! JUst got my 2013 BRZ a few days ago.............. Thanks!
Hello Thehark1 and welcome to BRZ ownership and the forum......
I see where you got your concern resolved.
I suggest, when driving this car, you just de-tune your ears a bit.
The car will usually show you a picture, if it's not happy ......
humfrz
Old 11-14-2016, 02:15 AM   #9
Brzerker
Brzerker's Avatar
Heh, then you're fine! It seems to be more pronounced with an aftermarket filter or intake system.
Old 11-14-2016, 03:50 AM   #10
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Mine does it too. '14.
Packofcrows is offline   Reply With Quote
Old 11-14-2016, 11:13 AM   #11
Thehark1
Drives: '13 BRZ
Thanks guys. I'm hyper sensitive to every noise because it's new. I am hearing a very audible ticking noise as well now. Sometimes it's chirpy and sometimes it ticks.
I guess these are all normal FA20 noises!
Old 11-14-2016, 11:28 AM   #12
Ticks are the injectors. Chirps is the fuel pump. Nothing broken and perfectly normal. Boxer engines sound like old Russian farm tractors and that is just the way they are. You will hear all sorts of noises in these cars. Other cars make the exact same sounds but since they have better soundproofing you just don't notice. You will also get loads of noises from the drive train that you never hear in FWD cars so if not used to RWD they will seem strange.
If paranoid from sounds you are gonna have a hard time with this car.
Old 11-14-2016, 11:51 AM   #13
Thehark1
Drives: '13 BRZ
Not paranoid, just uncertain of what to expect, but now that you guys have shed some light on the nature of this boxer motor, I feel much better!
Old 11-14-2016, 11:54 AM   #14
Yep they are noisy little buggers and I enjoy the racket since it helps bring the car to life.
"click" sound only when throttle is engaged, and dis-engaged AT BRZPDX Issues | Warranty | Recalls / TSB 50 10-11-2016 01:08 PM
On-throttle under-load "Dieseling" type noise... Header gaskets? Kostamojen Engine, Exhaust, Transmission 5 03-18-2016 07:50 PM
Ways for faster revving when blipping the throttle?? glamcem Tracking / Autocross / HPDE / Drifting 41 06-19-2014 01:16 AM
Clicking when blipping throttle Colpup Issues | Warranty | Recalls / TSB 7 06-09-2014 10:55 PM
"blipping" the throttle takes more that a blip?! KSC BRZ First-Gen (2012+) — General Topics 49 02-27-2013 07:04 AM
