Old 06-09-2014, 06:56 PM   #1
Colpup
Drives: Toyota 4runner Sport Edition
Clicking when blipping throttle
Been hearing a faint clicking noise when I first blip the throttle on downshifts. I don't hear it every time and so I haven't thought anything of it. Today I downshifted twice in a tunnel and it made the noise both times quite audibly. Both shifts were cruising at about 2.5k and then I blipped to about 3k and that's when I hear it. Time to take it to the stealership?
Sent from my HTC6525LVW using Tapatalk
Colpup is offline   Reply With Quote
Old 06-09-2014, 06:57 PM   #2
husker741
Tip-in knock. It's the shitty stock tune.
husker741 is offline   Reply With Quote
Old 06-09-2014, 09:46 PM   #3
BRZJunkie
Drives: BRZ Sportech
I also noticed it. Pinging. It does it most of the time when bliping hard. At all RPMs pretty much. I figured it was a rush mapping, shitty gas and 12.5:1 compression. I would be happy with 4 HP less but no pinging. I'll never be completely happy. It's my curse.
AND there's the crickets.
BRZJunkie is offline   Reply With Quote
Old 06-09-2014, 10:00 PM   #4
Colpup
I just noticed that my ac was on... It is much less noticeable when it's off. It's still loud compared to any knock or pinging I've heard in other cars...
On a side note when I gas up at the chevron by my house I have zero crickets. When I use shell they really come alive.
Now I really want a tune but I like my warranty more unfortunately.
Old 06-09-2014, 10:29 PM   #5
strat61caster
strat61caster's Avatar
This car has a drive by wire throttle, there's a little electric motor controlling the throttle valve, when you slam on the gas it goes to open as fast as it can hitting a mechanical stop, that's the clicking.
There's a thread on this exact topic further down, here's Dezoris' response, a logged track day with zero knock and the clicking clearly audible.
http://www.ft86club.com/forums/showp...20&postcount=3
ineedyourdiddly
Old 06-09-2014, 10:34 PM   #6
Colpup
Interesting read. That doesn't explain why it is noticeably louder when I had my ac on. And if that's the case wouldn't it make one click rather than numerous?
Old 06-09-2014, 10:40 PM   #7
strat61caster
Mine changes volume based on the stars, I never factored AC into it.
You could try to take it to the stealership but I doubt they'll do anything without a CEL or if it's easily repeatable, even then they'll just replace anything to say they've done the work, at least in my experience.
If you want a more concrete response you'll need to post up a video, there's so many rattles and clicks and clangs and every car is different enough that you'll get 6 different responses based off the same description (see above). Best of luck.
ineedyourdiddly
Old 06-09-2014, 10:55 PM   #8
BRZJunkie
This car is full of clicks and automated valves. Turning of the Ac kill some of them due to the compressor and such but the amount of pinging I get from blipping the gas pedal is bound to be on all the 86s, isn't it? So obvious? Or I have a problem few other have.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Ways for faster revving when blipping the throttle?? glamcem Tracking / Autocross / HPDE / Drifting 41 06-19-2014 01:16 AM
"blipping" the throttle takes more that a blip?! KSC BRZ First-Gen (2012+) — General Topics 49 02-27-2013 07:04 AM
Ignition and gas blipping video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 16 02-28-2012 07:17 AM
