Old 02-26-2013, 07:14 AM   #1
KSC
KSC's Avatar
Drives: Ion Redline
"blipping" the throttle takes more that a blip?!
Every car I've owned for the past 20+ years has been M/T, so in therory, I know what I'm doing. Normally when downshifting, in all my previous cars, a slight "blip" of the throttle with the side of my foot during heal/toe was all that was needed to rev match, but in this car I'm finding he RPMs fall almost immediately and much, much faster than everything else I'm accustomed to. I literally have to stab the gas peddle to the floor to keep the RPMs high enough for the lower gear. It's driving me crazy!
Every car is different, of course, but is there an specific explaination in regards to our car that is at play here? Maybe it's the shorter gear ratios that's throwing me off?
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 02-26-2013, 07:20 AM   #2
whaap
whaap's Avatar
I never got the "blipping" thing. While the clutch is in and my hand is down shifting a gear, my right foot is bringing the revs up to where I thiink they will want to be when I release the clutch which will be as soon as I'm in the lower gear. It's all very smooth.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
russv (02-26-2013)
Old 02-26-2013, 07:25 AM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
This car seems to want more of a blip than others I've had--just speed up your downshift & that'll help the match.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 02-26-2013, 08:04 AM   #4
KSC
KSC's Avatar
Drives: Ion Redline
@whaap: Unless you're downright riding the clutch,(and I know you're not) it looks to me like we're doing the same thing, it's just a difference on opinion of the definition of (or the duration of the) "blip".
@GTB: Yeah, I'll get used to it. What's probably throwing me off more is that I'm technically still in a "break-in", so I'm babying the clutch and shifting pretty slow. Still, the drop seems pretty dramatic. Just a tap to the accelerator on my IRL would give me 2-3k. The same tap on the BRZ is <1K.
Old 02-26-2013, 08:33 AM   #5
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
[QUOTE=KSC;757869]@whaap: Unless you're downright riding the clutch,(and I know you're not) it looks to me like we're doing the same thing, it's just a difference on opinion of the definition of (or the duration of the) "blip".
I believe WHAAP is describing an entirely different procedure. A 'blip', at least to me, is a short, quick depressing of the accelerator pedal. WHAAP's description does not include the 'blip' but is merely matching the engine revs to the speed he wants to get to when changing gears.
For instance, when going to a higher gear he would lower engine revs, when going to a lower gear he would increase the engine revs. It may be a slower gear change but he may not be in a racing mode.
BRZfan is offline   Reply With Quote
Old 02-26-2013, 08:38 AM   #6
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I've noticed this too... I double clutch my downshifts but it does require more than a "blip".. If I'm around 5500 in 4th I literally have to bring it up to redline when I blip the throttle on the downshift. I double clutch really fast but if you're slow at all it doesn't work out well on the FA20. I've learned that the more aggressive you drive this car, the more rewarding it is. It does seem to loosen up a little after a couple k on the odo but not much.
chadstyle is offline   Reply With Quote
Old 02-26-2013, 08:41 AM   #7
leon78
leon78's Avatar
Drives: 13 Whiteout
light weight pully
/thread
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 02-26-2013, 08:44 AM   #8
Foobar
SLO NO MO
Foobar's Avatar
I think whaapis describing a simple downshift whereas KSC is describing a downshift while braking since he mentions heel/toe and WHAAP mentions his right foot on the accelerator (nothing about the brake).
In any case, KSC - you'll get used to it. There seems to be less angular momentum maintained by the drivetrain when you let off the gas on this car, and if you get lightweight pulleys, it'll be even more pronounced.
I do find myself having to really time it right and apply the exact pressure needed whereas in previous MT cars (Honda/Mitsu/Jeep) it could be manhandled with less precision.
Old 02-26-2013, 08:46 AM   #9
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by leon78 View Post
light weight pully
/thread
Could actually make it worse, since a lightweight pulley will conserve less angular momentum. Yes, it spins up faster, but it also drops faster.
Old 02-26-2013, 08:51 AM   #10
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Get racerom with the downshift rev match function....
Fizz is offline   Reply With Quote
Old 02-26-2013, 08:56 AM   #11
whaap
whaap's Avatar
True. While I know how to heel/toe I don't while driving on the street/highway. I will down shift and get the attitude of the car where I want it before I enter a turn. I guess I learned that from many years of riding motorcycles.
Old 02-26-2013, 09:00 AM   #12
Foobar
SLO NO MO
Foobar's Avatar
I do the same. Some autocross guys prefer to keep their heel/toe method consistent on road and on track, but since I never track my car, and since I also had to learn how to shift safely on motorcycles, I do it your way.
Old 02-26-2013, 09:10 AM   #13
Suffa
Drives: Black GTS
I know the exact feeling, it's like the pedal has some lag in it.
Suffa is offline   Reply With Quote
Old 02-26-2013, 09:19 AM   #14
OrbitalEllipses
Drives: Attitude
light weight pully
/thread
I'd rather have a lightweight flywheel than a pulley. I have noticed the engine is slow to rev when blipping; sometimes I just don't give it enough gas on the downshift. Annoying, but like I said a lightweight flywheel would have far more impact than a pulley.
As far as shifting, you do want to shift before the turn. Shifting mid-turn is a no-no so getting it all done before the turn is standard. Especially in RWD cars, from what I understand. Braking, shifting, and turning at the same time requests more from the tires than just turning.
Sc0ob_do0D (02-27-2013)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
