Old 11-05-2016, 11:30 AM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Steering Stops
Does anyone know of adjustable steering stops to limit how far the front wheels turn? How do they look?
Update: See my 2nd post below.
Sent from my Pixel using Tapatalk
Old 11-05-2016, 12:14 PM   #2
switchlanez
I found this http://www.racingbytmg.com/wp-conten...anual_EN-1.pdf
"From the 2014 model on, steering stops have been installed in the GT86 CS-V3. These are also suitable for models from previous years.
The steering stops are mounted directly on the steering rod, under the dust cover. First of all the dust covers must be removed, and the steering rod dismantled.
The steering angle of the wheel is limited to about 25°."
1) Anyone know vendors who sell these?
2) If I remove the dust cover, can that be reused or will I have to get a new one?
3) What is the factory max steering angle spec?
Old 11-05-2016, 01:04 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Offtopic question - why would one want to reduce maximum steering angle? I'd rather love to see it being wider stock, but not willing to buy/install wide steering angle kit mods to front suspension.
Old 11-05-2016, 01:21 PM   #4
kingkenny
Drives: 2014 Toyota GT86
Track setup , having a brake duct and don't want to destroy it .
kingkenny is offline   Reply With Quote
Old 11-05-2016, 02:06 PM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I have done exactly this with assistance from Velox. All the details are on my blog post (site is a bit slow to load.) Very easy mod.
http://www.seriesblueadventures.com/...tment/
Stang70Fastback is offline   Reply With Quote
Old 11-05-2016, 02:19 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
One protest coming riiiight up.
(I kid... I would probably argue that it's a convenience mod anyway.)
Old 11-05-2016, 02:22 PM   #7
Stang70Fastback
A.K.A. Starlord
Lolol! At least I don't take my jack and foam bits out of my trunk!
Old 11-05-2016, 02:34 PM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
It's actually a very simple and effective approach, and convenience aside this might be a safety thing too. I think I have an issue on one side though I have no idea which wheel/tire combo causes it.
I don't take the foam out either, and the jack is legal (it's not secured so it might even be required).
About to go remove a few pounds of grime and dust (heck, it may be a few pounds of brake dust) and get things put away for the winter and prepped for a suspension overhaul.
Old 11-05-2016, 02:48 PM   #9
Stang70Fastback
A.K.A. Starlord
I wasn't referring to you! I was referring to He Who Shall Not Be Named!
Old 11-06-2016, 11:22 AM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
What, Voldemort?! I didn't know he was local. That explains the killings?
86 dies at stops Saviorself Issues | Warranty | Recalls / TSB 9 08-05-2016 04:00 PM
CEL, no power steering, speedometer stops, revs limited JustmySole Issues | Warranty | Recalls / TSB 7 01-24-2016 03:59 PM
AT not downshifting on hard stops finch1750 Engine, Exhaust, Transmission 5 10-12-2015 04:03 PM
Does anyone have their OEM bump stops that they're not using? CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-05-2014 09:02 PM
Changing fuel stops the chirp wbradley Issues | Warranty | Recalls / TSB 101 07-07-2014 04:46 PM
