Old 11-04-2016, 12:42 AM   #1
phrosty
Spencer Fabrication T5 Trans Swap
Spencer just posted this up, looks like an interesting option for all you boosted guys... http://www.spencerfabricationcompany...ion-conversion
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 11-04-2016, 01:00 AM   #2
FRS Justin
Drives: 2013 Asphalt FRS
I have been talking with Mark about this project since the idea was put on paper, and look forward to it being released... I love how he uses the automatic transmission bell housing. No more ugly cut and hack job bell housings.. Rest assured it will be simple bolt in unit once he gets it all put together.. Thanks Mark for letting this info out, it was killing me not to be able to talk about it!!!! I think I did pretty good keeping a secret for close to a year......
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 11-04-2016, 02:09 PM   #3
armstrom
Drives: none
It will all come down to how he prices the kit. A brand new T5 with high torque capacity can be had for well under $2k. I wouldn't presume to price his product for him but if he can keep the whole package price in the sub $3500 range then he should do quite well with these.
Sent from my XT1095 using Tapatalk
armstrom is offline   Reply With Quote
Old 11-04-2016, 02:33 PM   #4
Teseo
Drives: frs
I like the idea "plug-n-play". I would rather pay a little more and do the installation myself than pay someone to do a "hack" job
Old 11-05-2016, 03:19 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
With the idea trans without any gear work is good for 300ftlbs rated for a 3300lbs car, so 400ftlbs 500hp brz frs thats only 2700lbs should be safe as hell. You guy see 2nd gears top speed?? I think i read 74mph....
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-07-2016, 12:51 PM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
if i still had an fa20 in the car and didn't have a trans solution, id buy this no doubt. nice work
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-08-2016, 08:39 PM   #7
Dipstik-sportech
Dipstik-sportech's Avatar
Much like other domestic trans swaps this one will have the same issues. Improper gear ratio gaps for a lower torque engine and the inability to shift at higher rpm. I'd sooner get a par gearset than run a t5
Old 11-09-2016, 10:14 AM   #8
Icecreamtruk
Drives: Track preped NA FRS
What do you mean by inability to shift at higher rpm, if you dont mind explaining it a bit more? Thanks.
Old 11-09-2016, 09:06 PM   #9
Dipstik-sportech
Sure. Domestic engines generally don't rev as high as out small 4cyl cars do. Because of that the synchro design in the trans is usually designed to work better at a lower rpm. What most people find is you won't be able to get it into gear because the synchro can't keep up with the rpm and it will eventually wear them out. Not to mention everything inside is heavier so there is more inertia withing the gearset. Faceplating the trans fixes the issue but it's costly and not really street friendly. I know in my buddies Mustang with a t5 if you rev it over 6000rpm you'll never get it into the next gear no matter how hard you yank the shifter lol
Old 11-09-2016, 09:10 PM   #10
mrk1
Drives: Sterling BRZ Ltd
Shifting at high rpms is a chore for syncros and most T5's are pretty old tech in this department. The T5Z has carbon syncros.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-10-2016, 01:25 AM   #11
Dipstik-sportech
I'm actually surprised they chose to use a t5. There are much better and more up to date options that aren't much more expensive.
Old 11-13-2016, 09:15 AM   #12
mrk1
From Facebook, little more explanation.
"All right, we are going to spill the beans. Here is our transmission solution for the BRZ/FRS. What we are developing for the 86 is a different approach to the task of a trans swap. Rather then pick a trans first and figure out how to adapt it, we made the adapter first. What we started with is the OEM bell housing from the automatic transmission. Since its an OEM part that means straight bolt up, no cutting or welding to make the starter work. We engineered a sturdy 6061 Aluminum adapter plate that bolts to the bell housing and allows the installation of the gear box. This may seem like a simple and obvious idea but hey sometimes the best ones are. To meet the needs of our shop car we went with an upgraded Ford T5z transmission. However since we designed our adapter as a blank slate it is wide open to future development with even more transmissions. "
The Build Thread
Old 11-13-2016, 06:41 PM   #13
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I wouldn't mind a TKO 600 in the future if my PAR set ever gives out.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Big power fa20 parts/trans swap spitfire481 Engine, Exhaust, Bolt-Ons 18 11-26-2016 08:59 PM
LSx swap stock trans? Amir Ghadiri Engine Swaps 22 04-07-2015 07:37 PM
DIY - Air Spencer P@ul DIY (Do-It-Yourself) Guides 6 03-02-2014 02:04 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
