Old 07-20-2016, 09:34 PM   #1
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Big power fa20 parts/trans swap
Sold:
motor mounts
darton block
cylinder heads
pistons/rods
head studs
Ecutek
Intake manifold
Parts are apart and ready to go. Location is 21108 for local pickup or plus shipping. Engine parts are less than 500 miles, all in working condition with no issues. If anything was questionable, I wouldn't have it for sale.
Darton sleeved block. Has machined lip so the sleeves can not drop. Stock bore, no scratching or gouges. Light hone for ring seating and it's ready to go. No over bore required. Arp main stud kit installed. $1500
Oem heads with oem cams. Ferrea comp valves, ferrea dual springs and retainers. Decked before install, still looks perfect. Comes complete, all valves are shimmed to perfect spec. $1300
Manley turbo tuff rods with arp 625+ hardware
Je 9.5 Pistons with their largest wrist pins. $750 for the package
Fuel injector clinic 1650cc w/ plug and play harnesses. $700
Full blown intake manifold. $850
Full blown t4 turbo manifold. $600
Full blown fuel rails (no lines). $200
Custom arp L19 head studs. $200
Cusco motor mounts (not pictured). $160
ecutek cable/dongle. licensed to my stock ecu (new license required). $150
Complete tremec trans swap. Will take whatever an fa20 can throw at it. $6000
Faceplated tko600 with heat treated gears for shock absorption
Custom crossmember with poly mount (need to drill 6 holes)
Custom shifter setup (very minimal trimming, nothing visible inside the car)
Custom drive shaft shop aluminum driveshaft with chromoly tremec yoke
Custom fa20 to tremec bell housing
4 puck single disk clutch
Clutch master twin disk clutch (awaiting revised flywheel from cm)
Custom throw out bearing assembly and shift fork, uses oem slave cylinder
Tilton hydraulic throw out bearing setup (can use either setup)
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 07-20-2016, 11:37 PM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
pmed on most of the motor stuff
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 07-21-2016, 11:08 AM   #3
spitfire481
Drives: 2JZ FRS
pending sale:
motor mounts
darton block
cylinder heads
pistons/rods
head studs
MoTeC
Build Thread
@spitfire481
Old 07-21-2016, 11:11 AM   #4
spitfire481
Drives: 2JZ FRS
also have an ecutek cable/dongle. licensed to my stock ecu so you'd need a license when buying a tune. $150
MoTeC
Build Thread
@spitfire481
Old 07-21-2016, 09:36 PM   #5
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Subscribing! Depending coin and if they are sold before I can afford, interested in piston/rods and engine mounts. Don't want you to hold them though
COO86L is offline   Reply With Quote
Old 07-21-2016, 11:15 PM   #6
ORGANIZED-CHAOS
ORGANIZED-CHAOS's Avatar
Drives: 2014 FRS
PM sent
ORGANIZED-CHAOS is offline   Reply With Quote
Old 07-23-2016, 05:42 PM   #7
spitfire481
Drives: 2JZ FRS
Engine block, heads, pistons, rods, head studs, ecutek are sold. Mounts are pending
MoTeC
Build Thread
@spitfire481
Old 07-28-2016, 10:03 AM   #8
spitfire481
Drives: 2JZ FRS
mounts and intake manifold are sold. still have:
trans kit, fuel rails, fic 1650's, t4 turbo manifold
MoTeC
Build Thread
@spitfire481
Old 08-02-2016, 03:21 PM   #9
spitfire481
Drives: 2JZ FRS
MoTeC
Build Thread
@spitfire481
Old 08-19-2016, 01:39 PM   #10
spitfire481
Drives: 2JZ FRS
still have parts. also have a full blown fa20 to v160 adapter plate kit
MoTeC
Build Thread
@spitfire481
Old 08-23-2016, 10:35 AM   #11
spitfire481
Drives: 2JZ FRS
Fa20 to v160 adapter plate. $500 shipped
MoTeC
Build Thread
@spitfire481
Old 08-29-2016, 02:11 PM   #12
spitfire481
Drives: 2JZ FRS
FIC 1650's, plug and play $650
full blown fuel rails (no fittings) $140
full blown t4 turbo manifold $575
MoTeC
Build Thread
@spitfire481
Old 09-06-2016, 01:18 PM   #13
spitfire481
Drives: 2JZ FRS
go fast!
MoTeC
Build Thread
@spitfire481
Old 09-16-2016, 01:31 PM   #14
spitfire481
Drives: 2JZ FRS
still have
fic 1650 plug and play setup
also looking to sell my full plug and play motec m150 setup. includes customer jumper harness with gps connector, shift light module connector, connector for additional inputs/outputs. m150 ecu with license, and custom fa20 firmware that has basically any feature you could want unlocked (boost by gear, launch control, anti lag, traction control, rolling launch, etc). looking for $5200 for the whole package.
MoTeC
Build Thread
@spitfire481
Hollinger Sequential Trans for FA20 extreme-86 Engine, Exhaust, Transmission 38 01-16-2018 04:37 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB: FA20 and Six Speed Manual Trans Cross Want-To-Buy Requests 2 04-24-2016 12:06 AM
FA20 with V161 trans Dream20b Engine Swaps 18 02-03-2016 08:42 AM
Looking for an FA20, Trans and pieces in AZ Cross Arizona 27 04-03-2015 12:34 PM
