Old 10-28-2016, 11:08 PM   #1
JR Whiter
Drives: White 2013 BRZ
Unhappy Right Turn signal DOES NOTHING ???
Since my BRZ isn't going to be entering the Talladega 500 anytime soon I need to make right turns. When I make said turns I like to signal them to let other drivers know my intentions. When I flip up my signal NOTHING happens. No arrow clicking and flashing on my cluster and no lights. When I put my Hazards on ONLY the left side functions and the right does NOTHING. I think this might be a MULTIFUNCTION SWITCH fix but not sure... I'm pretty noobish when it comes to cars but I prefer to do everything myself for $$$ reasons. ANY insight would be awesome and if there it is the multifunction switch could someone point me towards a D-I-Y on how to replace it. Thanks all.
JR Whiter is offline   Reply With Quote
Old 10-28-2016, 11:24 PM   #2
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Someone more experienced with this will come along to assist but I will try to get the ball rolling.
Were there any changes that you did to the car before this happened?
The Twins make me smile
Old 10-28-2016, 11:37 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Do the windshield wipers come on when you make right turns? Because that happens to me.
Old 10-29-2016, 01:50 AM   #4
humfrz
NO ...... I'm NOT going to spoon feed you ....... but, I'd start by checking the fuses ....
(Oh, I see you're new ..... my post is sort of an inside joke .....)
humfrz for @Tcoat
Old 10-29-2016, 01:57 AM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Obligatory "Try refilling your blinker fluid" post
Originally Posted by humfrz
I'm old and lazy
Old 10-29-2016, 02:40 AM   #6
Ultramaroon
not playing cards
Ok, based on the wiring diagram, there are only a couple components that can fail causing the symptoms.
There is only one fuse, one tap to power. It splits between left and right in only the turn signal switch and the flasher module. I could tell you what I would do but it requires a certain level of experience. If you can interpret this diagram, you have a good start. If after studying this you have specific questions, I'll do my best to answer.
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
Turn Signal in OEM DRL/HiBeam? 636 Cosmetic Modification (Interior/Exterior/Lighting) 8 03-24-2015 04:46 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 06:06 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
