Drives: 2014 Subaru BRRRZ
Humming noise on left turns.
I have an pulsing humming noise whenever I am turning left from the LEFT wheel driver side. You can feel a slight vibration. I looked up to see if this was a wheel bearing issue but it seems like it would be the right wheel that should be making the noise. It pulses which make it seem like a tire issue and the rate of pulse increases with speed. I recently did get suspension installed. Anyone have any ideas what it could be? Thanks!
#2 | |
What have you checked? Did you get an alignment after the suspension install? |
#3 |
Was in a rush to post and forgot to specify. All that was installed were TRD springs. I had a mechanic friend check out alignment. It could possibly be that, I just wanted input to make sure before I go and do it.
#4 | |
Get an alignment... |
| The Following User Says Thank You to swarb For This Useful Post: | kphan (10-25-2016) |
#5 |
I suggest you get an alignment and mention to the tech what the car is doing.
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | kphan (10-25-2016) |
#6 | |
Tire pressures are normal levels. Car has 23k miles. Sounds are a like "Whoombb.......whooomb....." etc. It happened after installation of the springs. |
#7 |
Drives: '13 FRS - STX
Front or rear and at what speed?
Could just be hearing the LSD doing what it's supposed to. |
#8 | |
*Some really cool title*
If the alignment isn't correct than there could be possible rubbing issues either with suspension components or with the fender itself. Not saying that's exactly what's happening but you shouldn't take something like wheel alignment so lightly. And who installed the TRD springs? |
| The Following User Says Thank You to Silver Cervy For This Useful Post: | kphan (10-27-2016) |
#9 |
#10 | |
Thanks! |
#11 |
Drives: 15 BRZ LTD, 05 FXT
Yeah you need an alignment. It might not be what's causing the issue, but it's a good first place to start, and something you need anyhow!
| Fan static/humming noise | Zhangy | Issues | Warranty | Recalls / TSB | 8 | 08-26-2017 09:47 PM |
| New front sway, a little unstable on left turns | loading_please_wait | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 07-20-2015 07:38 PM |
| Humming noise while driving | maylchi | Issues | Warranty | Recalls / TSB | 9 | 03-13-2015 01:29 AM |
| help!! weird humming noise?? | sid94 | Issues | Warranty | Recalls / TSB | 3 | 05-17-2014 12:16 PM |
| Humming noise from the rear/gas tank? | Turbo95eg6 | Issues | Warranty | Recalls / TSB | 3 | 11-30-2013 04:10 PM |
