VTA or Recirculating Catch Cans
Which one is best? I've read so many reviews and what not and it's hard to find real evidence of which is better. What do you suggest and what brand?
Drives: Honda Accord Euro
Personally I would go the third way. Catch the junk and manually drain it when oil change.
...Just add nauseum
Drives: 2003 (AP1) S2000
Just vent it.
OEM's used to vent it, the only reason they don't now is emissions regulations, specifically regulations about unburned HC's. They used to just call them crankcase breathers. The boxer engines on airplanes and old Porsches VTA too, just irrelevant FYI. Ask any auto engineer if PCV in any form is a good idea, they'll all tell you it's a terrible idea, and its just there for emissions. A proper VTA will let nasty things like water vapor and blowby evaporate, let oil stay in the engine, and let crankcase pressure equalize with atmospheric pressure so seals don't blow out.. Nothing should build up in the can. Zero maintenence. Its the only sure route to keeping oil out of your intake tract where it doesn't belong.
There are many ways to displace.
-Spartarus |
#4 | |
Do you have a preference on brand? |
#5 | |
...Just add nauseum
Haha.
-Spartarus |
I'm not a picky man. I was looking at the FBM can but was unsure about others
#7 | |
...Just add nauseum
Annnd now I don't have an FRS to put it on.
-Spartarus |
#8 | |
What kit did you run their can with since you didn't use their turbo kit? |
Boost Creep
Drives: 2016 HyperBlue BRZ
Check out the new Velox AOS. Can operate basically however you want it to.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#10 | |
...Just add nauseum
Not a decision I'd make again. The build quality and engineering were unsatisfactory for me. Not bad, just not up to my standards, and nowhere close to OEM standards. I used the racerX can, also a very good option for recirculated cans. Got the MAP can intending to switch to VTA, and a different turbo kit, but never did it. Sold the kit, then later sold the car.
-Spartarus |
#11 |
Thanks for the replies. I guess I'll look around for more VTAs
#12 | |
Also racerx has the option of making their cans VTA 👍🏽 |
#13 |
Drives: WR Blue BRZ
I'd highly recommend the velox can great build quality amd can be run in vent or recirc.
Also great quality are the Radium cans, I swapped my Radium cans for the velox kit due to my supercharger interfereing with the Radium cans mounting so that is something to think about. |
#14 | |
I'll look into the velox |
| Radium Engineering Catch Cans | FRS2000 | Engine, Exhaust, Transmission | 111 | 03-02-2016 12:49 AM |
| ebay catch cans? | Basket Case | Engine, Exhaust, Transmission | 2 | 12-18-2015 09:04 AM |
| Catch cans: what are you running? | Apex Chase | Engine, Exhaust, Transmission | 144 | 08-14-2014 07:17 AM |
| Radium or Crawford catch cans/AOS | diss7 | Forced Induction | 16 | 02-18-2014 07:50 AM |
| cusco catch cans difference | Silverdub | Engine, Exhaust, Transmission | 15 | 04-23-2013 09:17 AM |
