Old 02-15-2014, 04:31 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Radium or Crawford catch cans/AOS
Now that I'm committed to turbo I need to make a call on which way to go on minimising blow by.
I was fairly well sold on the Crawford AOS, but looking at the Radium dual system, has me trying to weigh up the differences.
Interested to hear what others are using.
diss7 is offline   Reply With Quote
Old 02-15-2014, 04:34 PM   #2
jamesm
Do you want to recirculate or VTA?
Old 02-15-2014, 04:59 PM   #3
diss7
Technically I need to recirc, both street and track regs here don't allow VTA.
It's a fairly soft rule that isn't really enforced.
Old 02-15-2014, 07:44 PM   #4
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Personally I'd trust Radium anyday over Crawford...but that's just me. Radium backs every product up with solid engineering and Crawford...well their motors blow right before they release their built short block kit.
Zach3794 is offline   Reply With Quote
Old 02-15-2014, 08:03 PM   #5
jamesm
Radium cans are the worst value in the history of car modification. It's a catch can. If I were going to recirc I'd go with the avo can because it looks nice. Still crazy expensive for what you get, though.
Old 02-15-2014, 08:08 PM   #6
Zach3794
One thing I do hear about for the Crawford piece is that it rattles like all hell under the hood due to mounting location.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Old 02-15-2014, 08:18 PM   #7
olorin
olorin's Avatar
Drives: GBS Premium
I have the dual radium catch can kit. It's a very well made setup. Pricy for sure but worth it.
olorin is offline   Reply With Quote
Old 02-15-2014, 08:19 PM   #8
Zach3794
Every product they make is top notch quality, there's absolutely no denying that aspect.
Old 02-15-2014, 08:28 PM   #9
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I'm nervouse about recurculating in cold weather with condensation building up inside the can. Crawford even heats their aos in the wrx because its a problem but said it wasnt needed in this application because of underhood heat. I guess id have about 10 minutes of condensation every winter morning here then. But if your regulations say no vta then I guess its between Crawford and avo. If you can get away with it radium or fbm. I chose fbm because as nice as the radium is that price is crazy for catchcans.
Old 02-16-2014, 11:21 AM   #10
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
The Radium dual can set up does exactly what I want, functionally (vapor recirc to manifold, liquid stays in the can(s)) but it's stupid money. If no one buys the thing and the price comes off about a hundred bucks, maybe.
Chances are pretty good I'll be FI in a couple of months, so I'm looking this over too. What I know I'm not doing is trying to "economize" by returning fuel + oil + water + carbon to my sump. I suppose the Crawford could be hooked up to drain to a can rather than the sump, has anyone done this?
Edit: Just stumbled on these -- http://www.ft86club.com/forums/showthread.php?t=31544. This is a little closer to what I had in mind.
Ralph Spoilsport is offline   Reply With Quote
Old 02-16-2014, 03:47 PM   #11
quick108
Drives: Toyota
The Radium system is NOT vent to atmosphere (VTA).
quick108 is offline   Reply With Quote
Old 02-16-2014, 04:14 PM   #12
diss7
I'm still leaning towards Crawford. The Radium cans block the fender vents I intend on putting in.
Old 02-16-2014, 11:01 PM   #13
Reaper
Reaper's Avatar
Drives: violent
I realized I had confused d3pe with radium in my response
Old 02-17-2014, 12:09 AM   #14
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@MAPerformance mounts in a nice location
DIY | Radium Catch Can | Video | Full Technical Info Dezoris DIY (Do-It-Yourself) Guides 233 01-07-2020 02:12 AM
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 09:17 AM
AVO Inlets, Injen Intakes, Cusco Catch Cans, All In Stock! RallySport Direct Engine, Exhaust, Bolt-Ons 3 10-05-2012 12:39 AM
