Old 10-23-2016, 01:12 AM   #1
VABeachBRZ
VTA or Recirculating Catch Cans
Which one is best? I've read so many reviews and what not and it's hard to find real evidence of which is better. What do you suggest and what brand?
VABeachBRZ is offline   Reply With Quote
Old 10-23-2016, 09:15 AM   #2
JDM4E
Drives: Honda Accord Euro
Personally I would go the third way. Catch the junk and manually drain it when oil change.
JDM4E is offline   Reply With Quote
Old 10-23-2016, 09:50 AM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Just vent it.
OEM's used to vent it, the only reason they don't now is emissions regulations, specifically regulations about unburned HC's. They used to just call them crankcase breathers.
The boxer engines on airplanes and old Porsches VTA too, just irrelevant FYI.
Ask any auto engineer if PCV in any form is a good idea, they'll all tell you it's a terrible idea, and its just there for emissions.
A proper VTA will let nasty things like water vapor and blowby evaporate, let oil stay in the engine, and let crankcase pressure equalize with atmospheric pressure so seals don't blow out.. Nothing should build up in the can. Zero maintenence.
Its the only sure route to keeping oil out of your intake tract where it doesn't belong.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
1stGenBRZ86 (10-23-2016), VABeachBRZ (10-23-2016)
Old 10-23-2016, 11:52 AM   #4
VABeachBRZ
Originally Posted by Spartarus View Post
Just vent it.
Great information! Thanks.
Do you have a preference on brand?
Old 10-23-2016, 04:08 PM   #5
Spartarus
...Just add nauseum
Spartarus's Avatar
Depends on your preference for aesthetics and maintenence, but I wont say too much because I have one for sale and anything I say could be misconstrued as a shameless plug for my ad.
Haha.
-Spartarus
Old 10-23-2016, 04:11 PM   #6
VABeachBRZ
Haha.
I'm not a picky man. I was looking at the FBM can but was unsure about others
Old 10-23-2016, 04:15 PM   #7
Spartarus
...Just add nauseum
Spartarus's Avatar
Well, now that you know my opinion is biased, I can say I like the MAPerformance can the best... The one they include with their turbo kit. That's why I had them make me one.
Annnd now I don't have an FRS to put it on.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
Ultramaroon (10-23-2016)
Old 10-23-2016, 04:28 PM   #8
VABeachBRZ
What kit did you run their can with since you didn't use their turbo kit?
Old 10-23-2016, 04:57 PM   #9
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Check out the new Velox AOS. Can operate basically however you want it to.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
Old 10-23-2016, 05:10 PM   #10
Spartarus
...Just add nauseum
Spartarus's Avatar
Embarrassed as I am to say it, Speed By Design.
Not a decision I'd make again. The build quality and engineering were unsatisfactory for me. Not bad, just not up to my standards, and nowhere close to OEM standards.
I used the racerX can, also a very good option for recirculated cans.
Got the MAP can intending to switch to VTA, and a different turbo kit, but never did it. Sold the kit, then later sold the car.
-Spartarus
Old 10-23-2016, 05:13 PM   #11
VABeachBRZ
Thanks for the replies. I guess I'll look around for more VTAs
Old 10-23-2016, 05:17 PM   #12
VABeachBRZ
Also racerx has the option of making their cans VTA 👍🏽
Old 10-23-2016, 05:21 PM   #13
zypher
Drives: WR Blue BRZ
I'd highly recommend the velox can great build quality amd can be run in vent or recirc.
Also great quality are the Radium cans, I swapped my Radium cans for the velox kit due to my supercharger interfereing with the Radium cans mounting so that is something to think about.
zypher is offline   Reply With Quote
Old 10-23-2016, 05:34 PM   #14
VABeachBRZ
I'll look into the velox
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 01:49 AM
ebay catch cans? Basket Case Engine, Exhaust, Transmission 2 12-18-2015 10:04 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 08:17 AM
Radium or Crawford catch cans/AOS diss7 Forced Induction 16 02-18-2014 08:50 AM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 10:17 AM
