Old 10-13-2016, 10:56 PM   #1
HondaCBR08RR
Drives: Frs
Engine tapping sound
[ame="https://www.youtube.com/watch?v=JqgbFiToVoE"]Frs tapping sound - YouTube[/ame]
62k mile, no mods completely bone stock. The tapping sound is noticeable at 2000 rpm at the 0.20 mark. Side note the tapping occurs after warm up and noticeable when rpm comes up or down to 2000-3500 rpm. The tap is lightly noticeable during 4300-7000 rpm. I know it's hard to diagnose by video i would like to know what's your opinion on it. Ty
HondaCBR08RR is offline   Reply With Quote
Old 10-13-2016, 10:58 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Sounds like a bad lifter.
Old 10-13-2016, 11:55 PM   #3
humfrz
Yep, either a lifter with too much space or something else in the valve train.
Do you track your car .. ??
How long has it been making that sound .. ??
Back-in-the-day ..... with a 9/16" wrench, a screwdriver and a feeler gauge, we could have quieted that puppy down ......
NOW. look at this mess .......and that's just half of it ......
humfrz
Old 10-14-2016, 02:41 AM   #4
HondaCBR08RR
Drives: Frs
humfrz
The car is my daily driver never been track. Once in awhile I would go through the gears but never been in a race or track. Forgot to mention the car is a 6 speed automatic
The sound been like that for months.
How bad is this lifter problem? Should I continue to drive or take it to see a mechanic asap?
Old 10-14-2016, 03:11 AM   #5
humfrz
IF it is a lifter clearance problem, it's a pain to adjust the valve clearances. The cam bridges must be taken off to adjust the clearances which, MAY necessitate pulling the engine.
What I would do is get me a long screwdriver and place it around the engine compartment (with the soft end up to your ear) and see if you can isolate where the sound is coming from.
Then, I would take it into a dealer for an evaluation by their techs. Also, ask them if any necessary repair would be covered under warranty (it looks like you are close on that).
As far as driving it making that tapping sound, IF IT IS AN OUT OF TOLERANCE LIFTER, it shouldn't hurt the car ...... it's just not opening that one valve as far as it should be opened.
Keep us posted.
Hopefully others will be along with some more insight.
humfrz
Old 10-14-2016, 04:40 AM   #6
Impureclient
Drives: 2015 FR-S
It was a different engine but that video sounds exactly like a wrist pin failure I had. That engine died a horrible death soon afterward.
Impureclient is offline   Reply With Quote
Old 10-14-2016, 02:46 PM   #7
Ultramaroon
not playing cards
So hard to tell but on a second listen, it's disconcerting to hear it come and go at different speeds. Sloppy valves don't do that. They tap all the time.
Old 10-14-2016, 08:06 PM   #8
BRZnut
Drives: BRZ DGM Limited
Didn't someone on here have a bad vacuum pump that made a sound like the lifters? But I remember it being louder than the sound I am hearing in the video.
If you do find the cause, please post back!!
Old 10-14-2016, 09:06 PM   #9
Ultramaroon
not playing cards
Those have a bright/harsh intermittent knock but yes, I remember someone posted a good recording of it.
Old 10-14-2016, 09:32 PM   #10
humfrz
@HondaCBR08RR .... now, that would be easier to check, as opposed to tearing the engine apart.
Maybe put your screwdriver and ear back that way and give a listen .. ??
humfrz
Old 10-14-2016, 09:42 PM   #11
extrashaky
Drives: 2014 BRZ Limited
Or you can pull the cushions out of the couch and root around under all the car seats to scrape together $4 for an actual mechanic's stethoscope, which has a better, longer probe and better earpieces than a screwdriver.
http://www.harborfreight.com/mechani...ope-69913.html
Old 10-14-2016, 10:14 PM   #12
Ultramaroon
not playing cards
That's an absolutely terrible idea.
Old 10-14-2016, 11:14 PM   #13
humfrz
REALLY! Heck, anybody can find sounds with that thing ......
Besides, if you would get that thing even close to a FA20 engine ...... it would deafen you .......
humfrz
Old 10-14-2016, 11:39 PM   #14
Ultramaroon
not playing cards
humfrz
Yeah, or you could snag a staple or a nail digging around in your couch.
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Engine tapping sound on deceleration qtwre Engine, Exhaust, Transmission 5 05-09-2016 03:52 PM
Clutch Clicking/ Tapping sound nooserbtf Issues | Warranty | Recalls / TSB 3 05-04-2016 05:18 PM
Tapping sound above 70 mph Fugazi BRZ First-Gen (2012+) — General Topics 24 10-20-2015 04:04 AM
tapping sound coming from engine forgotten93 Issues | Warranty | Recalls / TSB 11 12-23-2013 09:54 PM
