Old 04-20-2016, 08:54 PM   #1
qtwre
Drives: White FR-S
Engine tapping sound on deceleration
Hi All,
There's a tapping sound coming from my engine area that only shows up when I'm decelerating in gear from about 2100-1600rpm.
My first thought was that it's an exhaust leak that only happens under a certain engine resonance but my mechanic tightened everything down. The sound is obviously in sync with the RPM so it isn't a rattle.
My question to you guys is if there is any known issue with the 2013 engines. I'm half expecting someone to tell me that it's injectors or valves or something.
The engine otherwise runs well. If I could ignore the sound I wouldn't have a complaint. I'm not yet convinced that it still isn't a tricky exhaust leak.
Thanks
qtwre is offline   Reply With Quote
Old 04-20-2016, 11:17 PM   #2
humfrz
What mods, if any, do you have ......??
MT or AT ....??
How long has it been doing it .. ??
humfrz
Old 04-21-2016, 07:11 AM   #3
qtwre
Drives: White FR-S
MT or AT ....??
humfrz
AVO turbo. No other engine mods.
MT.
It's been happening for maybe 200 miles.
I've heard of problems with cams and direct injectors. Does this sound like either of those?
Old 04-21-2016, 11:13 AM   #4
humfrz
MT.
I would suspect the turbo is making those sounds.
You may wish to check in over at the FI section for some opinions.
humfrz
Old 04-22-2016, 03:31 PM   #5
Bzives
I hear similar sounds in the same RPM range from time to time.. they seem to come and go.. I am completely stock except for a TRD intake and OFT stage 1 93 tune.
Bzives is offline   Reply With Quote
Old 05-09-2016, 03:52 PM   #6
PitViper
PitViper's Avatar
Drives: 2013 Scion FRS Limited Edition
I to have that sound. I never noted them begore till i took off the oem injector covers and installed the lovers. It sounds like valve chatter which is rather common in flat motors. Im also running an innovate supercharger and ither mods.
PitViper is offline   Reply With Quote
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Tapping sound above 70 mph Fugazi BRZ First-Gen (2012+) — General Topics 24 10-20-2015 04:04 AM
Engine/Drivetrain Squeak Upon Deceleration in Gear - 2013 M/T FR-S Purdue FR-S Issues | Warranty | Recalls / TSB 7 07-15-2015 08:47 AM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
tapping sound coming from engine forgotten93 Issues | Warranty | Recalls / TSB 11 12-23-2013 09:54 PM
