Old 05-01-2016, 12:31 PM   #1
nooserbtf
Drives: 2014 FRS
Clutch Clicking/ Tapping sound
Hey everyone.
I had an ACT street clutch and lightened flywheel installed about 2 months ago. I have noticed that there is a clicking/ tapping sound when car is cold and coasting to an almost dead stop. If I press the clutch pedal, the noise goes away. The car does not make the noise when warmed up, unless the a/c is on. If I am in traffic at a dead stop and the a/c is on the clicking/tapping happens until I depress the clutch pedal. Sounds like it is coming from the clutch/ transmission area. Any ideas or similar issues? When the clutch was installed I used motul fluid. Any help would be greatly appreciated, Also the clutch and flywheel were "professionally installed".
nooserbtf is offline   Reply With Quote
Old 05-01-2016, 12:44 PM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Judging by when you say it happens, it sounds like either typical gear chatter or a failing throwout bearing to me. Have you always had these noises? Does it only go away if the clutch is depressed fully disengaged or will it go away with just slight pressure on the pedal?
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 05-04-2016, 04:54 PM   #3
nooserbtf
Drives: 2014 FRS
Thanks for the reply. The car has only made the noise since the new clutch and flywheel kit. The noise is only there when I am completely off the clutch pedal with a/c on. It does go away if I depress the clutch in slightly (maybe 2 inches or so). Also goes away when clutch pedal is completely depressed.
Old 05-04-2016, 05:18 PM   #4
zkv476
zkv476's Avatar
If it started with the new clutch I wouldn't be too worried as long as the trans drives normally and feels normal. The lightweight flywheels tend to cause the trans gears to chatter especially with the A/C on since the engine RPM is less smooth. Two inches of clutch travel usually disengages the clutch, which would stop the trans gears from spinning and also stop the chatter. You may also have rattling noises when decelerating in between 2k-3k RPM that's also related to this.
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
Strange clicking sound when clutch is engaged? synchromesh Issues | Warranty | Recalls / TSB 0 11-12-2014 12:13 PM
clicking/tapping noise when shifting semi hard Skurge Issues | Warranty | Recalls / TSB 3 09-20-2013 04:37 PM
