Old 10-06-2016, 09:33 AM   #1
VTEC
Drives: Scion FR-S
How long for stock ECU to reach IAM 1.0?
I recently just did a repair to seal a leak in the intake that was causing a lean code and dropping the IAM. The lean code is gone and I've been monitoring the IAM on my OFT to make sure everything is completely back to normal. On a Stage 1 93 octane tune running 94 octane fuel I can get the IAM to stay at 1.0 for a good half hour drive that includes full throttle pulls to the redline.
On stock tune, the ECU resets the IAM to 0.7 on startup which I've searched here is normal. It does gradually go up to .82 after a few blocks then .94 and after more than half an hour it did eventually hit 1.0.
My question is, does anyone know if it's normal for the ECU to take half an hour or more for the IAM to reach the full 1.0? Or is it slower if you recently just flashed it back to stock? It just sounds kinda dumb that the ECU is programmed to withhold maximum power for such a long time. Or maybe I am still leaking a small amount of air?
Instagram: @racecar_4life
VTEC is offline   Reply With Quote
Old 10-06-2016, 10:05 AM   #2
wparsons
wparsons's Avatar
It's not time based, it has to meet certain conditions before it'll raise the IAM. IIRC a steady sweep from 2500-6000rpm above half throttle will raise it. Do that a few times and it should be at 1.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
VTEC (10-06-2016)
Old 10-06-2016, 05:21 PM   #3
VTEC
Drives: Scion FR-S
Thanks. I've been trying that Vishnu reset between 2000 and 6000 RPM. Sometimes full throttle, light throttle, half throttle. It's still kinda slow to raise the IAM. And obviously I need to make sure I have enough space to do it safely.
I actually found it was faster to put it in 6th and give it half throttle at low rpms. And easier since I don't need much space to accelerate.
I still think it's kinda dumb since nobody would purposely lug their engine like that.
Old 10-06-2016, 05:37 PM   #4
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Bit of a shot in the dark but maybe the stock tune starts it at .7 so people are less likely to have knock/oil starvation before the oil/fluids are up to operating temps?
I guess you could test by cold starting the car and seeing if IAM gets up to 1 by the time oil is at least 180*F without driving it at all
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 10-06-2016, 05:42 PM   #5
steve99
you also need to have little or no knock occurring or it does not work.
The stock tune knocks quite a lot in 2000-4000 area depending on fuel so it will sometimes be difficult to get iam to return to one, you need to be almost knock free.
The Vishnu trick relies on you running the engine through the rpm range at light throttle and low load, this should be the conditions for low or little knock so the ecu will detect this and return iam to one.
however if you still get knock in an rpm load range iam will stay below 1, until your pretty well knock free or very limited knock.
Aftermarket tunes are usually heaps better knock wise than stock tune hence the iam is solid at one.
log the flkc and fbkc knock parameters, if your seeing consistent knock iam will never get to 1
Old 10-06-2016, 05:48 PM   #6
steve99
stock is set to 0.7 to cope with crap fuel in some contries like south Africa where only 95 ron (less than 91 usa fuel is available). Same tune in all countries.
If your fuel is good iam will quickly climb to 1, if its not it will stay below 1 or even move lower than 0.7 to limit knock and protect engine.
Tuners generally set iam to 1 as they tune for a specific fuel and also the y don't want to have to mess around waiting for iam to climb to 1 before they do dyno runs after each flash. It will still decrement on knock.
the iam setting is just the initial value after flashing or reset of ecu. Then ecu learns a suitable value for iam based on knock it sees, this is then remembered and adjusted until the ecu is reset/reflashed. ie once the iam learned value will then be used for subsequent startups, its only reset to initial value on reset/reflash
Tectoniic (10-06-2016)
Old 10-06-2016, 05:51 PM   #7
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
snip
Everytime I think I have a decent idea/guess steve just has to come in and kill it with his knowledge
Thanks again!
Old 10-06-2016, 05:59 PM   #8
steve99
Thanks again!
ha ha :-)
when ever you get concerned about a bit of knock take a look at this log from a stock car, stock tune in South Africa on the best fuel they can get 95 RON (about 91 usa) and these guys track cars on this fuel
IAM 0.2
still getting -2 -3 degrees FLKC
http://www.datazap.me/u/steve99/sout...2-20-28&solo=2
Old 10-07-2016, 03:29 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Won't work. There are RPM and load parameters that have to be met, hence having to load the engine up.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-07-2016, 05:30 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes this is true. Stock tune starts with .7, but tuners like to set it to 1. Main issue I can see is when you want to install a new peripheral and the instructions say to reset the ECU (e.g. disconnect/reconnect battery) . It makes sense to start with an IAM .7 setting and let the car gradually learn the new peripheral, than rushing things ...
Old 10-07-2016, 06:25 PM   #11
VTEC
Drives: Scion FR-S
Thanks everyone. IAM rose really fast this morning. As soon as I got on the main road I gave it gas at low revs and it shot up to 1.0 before the engine even warmed up. Leaving work was another story. Was stuck in traffic for quite a bit and it wouldn't budge at all from 0.7. Even if I gave it gas in 1st and 2nd gear at low revs. Probably because it accelerates out of the low RPM range too quickly. But once the traffic cleared up and I could use low RPM in 5th and 6th gear the IAM shot up to 1.0 quickly again.
In both cases once the IAM reached 1.0, it never fell back down even under full throttle and high RPMs.
I think I can be reasonably confident now that the intake was repaired properly. I just didn't realize how horribly slow the stock ECU can sometimes be in raising the IAM. I wonder if some people are tracking their stock car at 0.7 IAM and don't even realize their engine is not at full power.
Old 10-07-2016, 07:17 PM   #12
steve99
IAM is dropping as you must have significant knock for the tune and fuel combination your using. The stock tune is very knock prone arround 2000-4000 rpm under medium to high loads on anything but the best fuel.
most tuner roms are significantly better in this area, you iam is dropping as its the ecu safety mechanism to protect engine when significant knock detected.
Try a different brand of fuel some are way better than others even with same octane rating
Old 10-08-2016, 02:55 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-08-2016, 04:22 AM   #14
steve99
Originally Posted by Kodename47 View Post
assumed his iam was 1 then dropped in traffic to 0.7 while driving :-)
also on my tuned roms (iam initial set to =1 ) if iam dropped below 1 I could never reset it to one by just turning ignition off, had to drive it and do a couple of light throttle runs.
assume this will be same for stock rom ? ie 0.7 initial after flash/reset, but then ecu remembers last iam reading on startup.
Some goals to reach for my FRS in 2016 yzhang Scion FR-S / Toyota 86 GT86 General Forum 15 01-20-2016 07:29 PM
How often can I reach red line ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 62 04-23-2015 01:00 PM
Possible to reach fumoto without lifting? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-23-2014 04:36 PM
First to reach 1,000 miles? dietz Scion FR-S / Toyota 86 GT86 General Forum 22 05-31-2012 11:43 AM
