Old 10-06-2016, 12:14 AM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Front Lower Air Dam Removal?
Hey everyone. I want to install some things in the space between the bumper and the radiator, but I don't want to take the front bumper off for several reasons.
I haven't had a good chance to look at the car yet, but I'm curious if anyone knows offhand if it's possible to remove the lower air dam, which would allow me to reach up from underneath and work on stuff in that space? It seems like it's at least a lower and an upper piece, so maybe it isn't that simple.
Stang70Fastback is offline   Reply With Quote
Old 10-06-2016, 01:58 AM   #2
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
I've done it...That's how I installed my Hella's ")
vintagemxer is offline   Reply With Quote
The Following User Says Thank You to vintagemxer For This Useful Post:
Stang70Fastback (10-06-2016)
Old 10-06-2016, 02:05 AM   #3
Stang70Fastback
A.K.A. Starlord
Im intending on installing some horns too... they're just a bit bigger than Hellas, lol. Good to know that's a way to get in there. Thanks! Anything I should know, or is it pretty easy to figure out once you get under there?
Old 10-06-2016, 02:09 AM   #4
ryoma
ryoma's Avatar
it's pretty easy getting the bumper off once you've done it once. don't have you worry about getting your arm all scratched up and uncomfortable on the ground
Old 10-06-2016, 02:20 AM   #5
Stang70Fastback
A.K.A. Starlord
I have giant ESCO stands so I can raise the car very high off the ground. There are several reasons I don't want to remove the bumper, including:
- This will be a long-term project and I don't want to keep taking the bumper off and on endlessly, since I'm not driving around without it.
- I don't want to unnecessarily risk "bumper sag" if I can avoid it.
- I need the bumper in place to determine how much room I have.
Old 10-06-2016, 08:34 AM   #6
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Same here.
It's super easy. It's just plastic rivets and few bolts. It's one of those things where after you're done you feel stupid for overthinking it and tell yourself "There was absolutely nothing to worry about with this"
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
Stang70Fastback (10-06-2016), Tcoat (10-06-2016)
Old 10-20-2016, 11:31 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
@Stang70Fastback here's some pictures to help you out.
  1. In the first picture you can see the 2 pieces that have to come out. One is a skin under the car and the other is like a false floor that goes right under the opening in the grill.
  2. The second picture shows how they are assembled when on the car.
  3. The third picture shows the opening from the ground looking up (in this picture I already removed the stock horn).
Notes:
See those 5 holes in the false floor piece? That's the openings for the pressure clips. I actually tape OVER them to stop debris from going in there and making the clips harder to remove in case I ever needed to take this off again.
There are 2 pressure clips that install onto the false floor piece from the TOP going DOWN. They're at the sides and they hold vertical walls near the left and right of the opening.
The Following User Says Thank You to Joon525 For This Useful Post:
Watch Me Run (10-22-2016)
Old 10-20-2016, 11:36 PM   #8
Joon525
Joon525's Avatar
Drives: 2016 BRZ
I'll post up how I installed my horns in there soon...I did it a different way than most (if not all) on here.
Front Sway Bar Removal slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 04-22-2016 06:58 PM
removal of front pipe help MileHighBRZ Engine, Exhaust, Transmission 9 04-20-2015 08:19 PM
TRD Style ABS Front Bumper Lip, CFW Trunk Spoiler, LH Lower Control Arm Front STS-V Want-To-Buy Requests 0 03-18-2014 04:42 PM
Front fender removal pemill DIY (Do-It-Yourself) Guides 3 02-20-2014 03:48 PM
front bumper removal? ft86me DIY (Do-It-Yourself) Guides 4 06-10-2013 01:28 PM
