A.K.A. Starlord
Drives: 2015 Series.Blue
Front Lower Air Dam Removal?
Hey everyone. I want to install some things in the space between the bumper and the radiator, but I don't want to take the front bumper off for several reasons.
I haven't had a good chance to look at the car yet, but I'm curious if anyone knows offhand if it's possible to remove the lower air dam, which would allow me to reach up from underneath and work on stuff in that space? It seems like it's at least a lower and an upper piece, so maybe it isn't that simple. |
#2 |
Drives: 2016 BRZ Limited
I've done it...That's how I installed my Hella's ")
| The Following User Says Thank You to vintagemxer For This Useful Post: | Stang70Fastback (10-06-2016) |
#3 |
A.K.A. Starlord
Im intending on installing some horns too... they're just a bit bigger than Hellas, lol. Good to know that's a way to get in there. Thanks! Anything I should know, or is it pretty easy to figure out once you get under there?
#4 |
it's pretty easy getting the bumper off once you've done it once. don't have you worry about getting your arm all scratched up and uncomfortable on the ground
#5 | |
A.K.A. Starlord
- This will be a long-term project and I don't want to keep taking the bumper off and on endlessly, since I'm not driving around without it. - I don't want to unnecessarily risk "bumper sag" if I can avoid it. - I need the bumper in place to determine how much room I have. |
#6 |
Drives: 2016 BRZ
Same here.
It's super easy. It's just plastic rivets and few bolts. It's one of those things where after you're done you feel stupid for overthinking it and tell yourself "There was absolutely nothing to worry about with this" |
| The Following 2 Users Say Thank You to Joon525 For This Useful Post: | Stang70Fastback (10-06-2016), Tcoat (10-06-2016) |
#7 |
Drives: 2016 BRZ
@Stang70Fastback here's some pictures to help you out.
Notes: See those 5 holes in the false floor piece? That's the openings for the pressure clips. I actually tape OVER them to stop debris from going in there and making the clips harder to remove in case I ever needed to take this off again. There are 2 pressure clips that install onto the false floor piece from the TOP going DOWN. They're at the sides and they hold vertical walls near the left and right of the opening. |
| The Following User Says Thank You to Joon525 For This Useful Post: | Watch Me Run (10-22-2016) |
#8 |
Drives: 2016 BRZ
I'll post up how I installed my horns in there soon...I did it a different way than most (if not all) on here.
| Front Sway Bar Removal | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 04-22-2016 05:58 PM |
| removal of front pipe help | MileHighBRZ | Engine, Exhaust, Transmission | 9 | 04-20-2015 07:19 PM |
| TRD Style ABS Front Bumper Lip, CFW Trunk Spoiler, LH Lower Control Arm Front | STS-V | Want-To-Buy Requests | 0 | 03-18-2014 03:42 PM |
| Front fender removal | pemill | DIY (Do-It-Yourself) Guides | 3 | 02-20-2014 02:48 PM |
| front bumper removal? | ft86me | DIY (Do-It-Yourself) Guides | 4 | 06-10-2013 12:28 PM |
