Drives: 2014 BRZ Limited
removal of front pipe help
I tried to install my new front pipe, the read bolts were easy to access. However, with just jack stands I had to give up on removing the 2 bolts near the cat. The problem is, the way it's angled I couldn't fit in my socket, so I tried to use a wrench to no success.
Any tips on how to remove the bolts near the cat so I can install my new front pipe would be great thanks |
Drives: frs
Bring a pair of hands. Beers and pizza also
Drives: Fast
Use two wrenches. Also helps to be on a lift for the front pipe.
Drives: 2012 Toyota 86
yeah just use a cheater bar, the front 2 bolts are studs, so no need to grab on to the back end.
BReeZy Hunter
Drives: 13 DGM BRZ Limited 6MT
i sprayed pb blaster on the bolts first and then used a wrench with a rubber mallet.
Drives:
Wd40 and a mallet did the trick for me. It did give me issues though.
Ok guys I got it off. Then installed my berk catless testpipe. I'm hoping I didnt tighten something and I have an exhaust leak. Because with just the berk frontpipe I have major drone!! It gives me q headache and sounds terrible.
Do catless front pipes alone create major drone and noise? Or do I have a leak? |
yeah the front cat is a huge noise canceler. but if your running stock everything else, it shouldn't be that loud. Maybe your ears are just really use to the whisper quiet full stock set up.
#10 |
I didnt have it clamped down enough from the testpipe to the stock exhaust. Its still much louder then expected
| HKS front pipe or dual resonated front pipe | unsurety | Engine, Exhaust, Transmission | 18 | 02-22-2016 09:22 AM |
| Gains from aftermarket catted front pipe vs stock front pipe? | Vmax911 | Engine, Exhaust, Transmission | 4 | 01-20-2014 01:42 PM |
| Will a resonated front pipe make alot less noise than test pipe? | Mike86 | Engine, Exhaust, Transmission | 8 | 01-26-2013 07:24 PM |
