Old 10-02-2016, 10:24 AM   #1
Chad_W
Drives: 2013 BRZ DGM
Muffler Bypass Valve
Has anybody attempted a custom bypass valve like this? I think it could be a good set-up for those of us who want a little bit of a Jekyl and Hyde experience.
Chad_W is offline   Reply With Quote
Old 10-02-2016, 10:32 AM   #2
Chad_W
A unit like this might be perfect for it
https://www.summitracing.com/parts/q...c225/overview/
Old 10-02-2016, 10:39 AM   #3
JoeC
Drives: Subaru BRZ Limited
I have a buddy who did this on his highly modified legacy GT. It's pretty wicked just dumping out to a straight pipe.
JoeC is offline   Reply With Quote
Old 10-03-2016, 12:22 AM   #4
Iceman
Iceman's Avatar
Drives: GT86
I know someone who's done it:
[ame="https://www.youtube.com/watch?v=464bFBbjNLA"]GT86 sound by pass móvil - YouTube[/ame]
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
Old 10-03-2016, 01:15 AM   #5
humfrz
To me, that doesn't look/sound like it would be worth the money, time and trouble.....
Now, back-in-the-day, when we would place the cut-out at the first turn in the exhaust pipe ........ THAT made a wicked sound ......
(but, they usually leaked .....)
humfrz
Old 10-03-2016, 10:57 AM   #6
Chad_W
I like the way the system tucks up under there, but I'm not so sure about the exhaust note....louder isn't always better. I guess the only way to really tell if you like it to try it with whatever exhaust you have because your header/frontpipe/midpipe is definitely going to effect your final outcome
Old 10-03-2016, 11:07 AM   #7
Wil
Wil's Avatar
Drives: Drives like a crab.
Hi,
I'm actually doing something pretty similar.
Discover it here:
http://www.ft86club.com/forums/showthread.php?t=111280
Wil is offline   Reply With Quote
Old 10-03-2016, 04:17 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
But way valve is routed here makes it look simpler then also cutting muffler.
Still, loving idea itself, quiet when cruising or starting up in quiet neighbourhoods, and loud when you want it to be with simple press of a button.
Old 10-03-2016, 06:38 PM   #9
Chad_W
Originally Posted by Wil View Post
Hi,
Discover it here:
That is a pretty bold approach! I like the idea, why did you choose such a invasive set-up instead of a more external one?
Old 10-04-2016, 05:20 AM   #10
Wil
Wil's Avatar
Because the valve I ordered is so big there was no other choice!
The setup Iceman shared with us is pretty neat.
But the guy in the video is using another kind of valve, a smaller one (the size of a turbo blow off valve).
The advantage of my setup is that I can easily replace the valve if it fails.
Since I am sometimes "trackdaying", the valve will be exposed to very high temperatures and, honestly, I doubt it will resist in such conditions, even if it looks pretty well-built.
PCV Valve Replacement with STI Valve apelpapa Forced Induction 30 06-03-2022 08:23 PM
BRZ Nav Bypass lxsedan CANADA 43 03-30-2015 07:44 AM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
tpms bypass? d.liang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-24-2014 03:32 PM
Which Blowoff/Bypass Valve do you use? qtwre Forced Induction 13 02-09-2014 08:04 PM
