Old 09-30-2016, 07:09 AM   #1
6pack
6pack's Avatar
Drives: GT86
Question OBDII socket malfunctioning
Hello there,
the OBDII socket below my dashboard have a problem.
Some of the pins do not make proper contact probably because I used the socket a lot.
Either they got loose or recede while inserting a plug; they fail to make contact and I'm cut off from accessing the car's electronic.
This causes me trouble when:
- Connecting to Ecutek to program or check my maps settings
- Connecting to my OBDII dongle for Torque
- Even connecting to the standard Toyota diagnostic to, for example, make a car key duplicate.
In principle I should go to my Toyota dealer and replace the socket with, possibly, part of the cabling leading to it.
Does anybody here ever had a similar problem?
If yes, how did you fix it?
Any tip, recommendation, docs to look at?
There are any posts I should read?
Thanks in advance.
6pack is offline   Reply With Quote
Old 09-30-2016, 01:42 PM   #2
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
there is a thread or two on the forum that people talk about the same issue, the best thing to do would be to get an OBD splitter or extension. people found that the connector we have kind of sucks and ran into the same issue you have. so if you can get an extension and plug it in then when you plug something into the extension then you are no longer wearing out the stock/oem one. you just have to make sure to get the extension installed and working the first time and you're gold after that.
otherwise in the same thread i remember someone saying that they bought a whole new connector, pins, and crimper to completely redo the obd port. i think that's way more expensive and a much higher chance of screwing up.
phanguy is offline   Reply With Quote
Old 09-30-2016, 01:56 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
I've got the same problem. How does the extension connect any better than the failing dongles? Tried 3 different bluetooth dongles and each one disables my dashboard after a minute or 2 of driving.
Trying to search for the most relevant and helpful threads. ..
Toyarzee is offline   Reply With Quote
Old 09-30-2016, 02:03 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
The extension doesn't connect any better, he's saying the use of one will prevent wear and tear (constant plugging and unplugging) on your OEM OBD port but if you are having connectivity issues (bent/damaged pins) then it is already too late.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
phanguy (09-30-2016), Toyarzee (09-30-2016)
Old 09-30-2016, 02:10 PM   #5
Toyarzee
Shibby!
Toyarzee's Avatar
My very first connection was a failed one, so definitely not from wear or tear... dang
Old 09-30-2016, 02:13 PM   #6
STV3
Señor Member
STV3's Avatar
I was having the same issue when getting my inspection this year. The inspection machine would not make a complete connection to my car therefore it could not pull the info from my car that it needed.
Bought an extender for like $14 on Amazon. I made sure that it had nice thick pins and it worked first time like a charm.
STV3 is offline   Reply With Quote
The Following 2 Users Say Thank You to STV3 For This Useful Post:
6pack (10-01-2016), Toyarzee (09-30-2016)
Old 09-30-2016, 02:32 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Ah, I see. That is odd that you didn't have any luck after 3 different BT adapters. I would suggest taking your car to the auto parts store to see if their OBD2 scanner works on your car but it'd be fruitless since you aren't throwing any codes.
Current DD: M235i
Old 09-30-2016, 02:52 PM   #8
Toyarzee
Shibby!
Toyarzee's Avatar
Mind sharing which one you bought?
Old 09-30-2016, 03:37 PM   #9
STV3
Señor Member
STV3's Avatar
Here ya go
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
6pack (10-04-2016), Toyarzee (09-30-2016)
Old 01-09-2017, 01:24 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
this happened to me, i ended up buying a new OBD2 socket, pins, and crimper. Cut the OEM connector off, repinned the wires, installed them in the the new housing and it's fixed.
i also installed a 90 degree OBD2 splitter at the same time so that way all wear/tear on the pins will happen on to the splitter and not the car-side connector.
The Following User Says Thank You to xjohnx For This Useful Post:
6pack (01-12-2017)
Old 01-12-2017, 11:51 AM   #11
6pack
6pack's Avatar
Drives: GT86
Thanks John, this is what I'm going to do exactly.
The 90 degree splitter it's a good move. It preserves the new socket to be abused again.
Did you buy socket and pins from Toyota/Subaru dealer or just any OBD2 kit?
I'm not expecting a dealer to sell the crimper tool of course...
Old 01-14-2017, 01:58 PM   #12
xjohnx
Grip>Slip
xjohnx's Avatar
I used this crimper: https://www.bmotorsports.com/shop/pr...roducts_id/617
this connector:
https://www.bmotorsports.com/shop/pr...oducts_id/1928
and these pins:
https://www.bmotorsports.com/shop/pr...oducts_id/1564
6pack (01-23-2017)
diagnostic, obd2, obdii, socket
OBDII socket trouble 6pack Software Tuning 6 07-21-2015 12:54 AM
Which LED bulb/socket? whip DIY (Do-It-Yourself) Guides 5 09-04-2014 02:44 AM
Socket Set MrMista Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-28-2013 03:21 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
