Old 07-15-2014, 11:26 AM   #1
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
New MAP sensor question
Hey guys, I understand that the stock MAP sensor can only read up to ~6 psi, and that is what I am seeing in Torque.
If I were to upgrade my MAP sensor to something like a 1 or 2 bar sensor (something from delicious tuning for example) would torque be able to read PSI more accurately without making any other changes to the ECU software?
TLR: Can I upgrade my MAP sensor to get a more accurate PSI reading without also getting a new tune at the same time.
Thanks!
Old 07-15-2014, 01:25 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
You'll have to change the tune as the MAP sensor calibration has to match the new sensor. After that though Torque should be just fine.
Your problem isn't really that you can't see the right boost on Torque, but likewise the ECU doesn't see how much boost you're actually making, which would make me very nervous.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
Sportsguy83 (07-15-2014)
Old 07-15-2014, 04:23 PM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
yes, you are correct, it is risky. Waste gate spring and manual boost controllers are my "failsafe" right now. Nothing is set higher than my AVO map tune right now.
Thanks for the help! Looks like I will dip into the funds sooner rather than later.
o2 sensor question for tsudo catback/downpipe giorgi0424 Engine, Exhaust, Transmission 8 07-04-2014 10:22 PM
Map Sensor Question SunkenFRS Engine, Exhaust, Transmission 1 03-11-2014 04:41 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Question on sensor placement for the Torque app. zooki Engine, Exhaust, Transmission 2 01-01-2014 05:20 PM
