Old 05-24-2013, 01:02 AM   #1
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Gas mileage goes up after header install
Hey
After installing my FA20club EL headers I realized that when I press the gas pedal hard my l/km goes up to 50L , it also makes a weird fluttering noise... I'm convinced there's a leak somewhere. I was thinking maybe the OEM header gaskets are too thin..
Anyone else get this problem?
I even changed my whole exhaust to stock OP invidia catless front pipe resonated am q300 cat back
I'm gonna be installing the fa20club turbo kit soon
Scalzo is offline   Reply With Quote
Old 05-24-2013, 01:58 AM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by Scalzo View Post
Hey
fluttering usually means something might be leaking. If you feel its from the front, i'd re check that everything is torqued up correctly because usually re using the oem gasket wouldn't cause such issue ( apart them being friend prior to the install )
Old 05-24-2013, 05:22 PM   #3
Scalzo
Scalzo's Avatar
I'll have to check when I install my turbo kit
Old 05-24-2013, 06:07 PM   #4
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Check the vband. Mine was a little finicky but got it to seal on second adjustment.
Sent from my SPH-L710 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 05-24-2013, 06:08 PM   #5
NickFRS
Drives: 2013 Asphalt FRS
OEM subaru gaskets are a crush style gasket. Resuing them usually is okay but you should always replace a gasket once it's torqued and un torqued.
On another note the gaskets are 36 bucks from my local shop. Not expensive.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-24-2013, 06:44 PM   #6
Scalzo
Scalzo's Avatar
Hmm I'll double check when I get the turbo kit since ill have to remove it..
I could probably get them free at Toyota, I'll see first if its the vband
Old 05-24-2013, 06:53 PM   #7
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I'll be using copper permatex on mine when it arrives. I had to use it on my motiv overpipe and hfc as well. How you like the header otherwise?
FastLane1000 is offline   Reply With Quote
Old 05-24-2013, 11:28 PM   #8
Scalzo
Scalzo's Avatar
What's copper permatex? right now I'm running front pipe catless and catback with the headers and I love the growl.. I'm waiting for invidia to come out with an over pipe .
SARD Japan Header & Mid-Pipe & Header & ECU nigel-jdmparts Engine, Exhaust, Transmission 63 01-21-2014 12:20 PM
How much mileage on your FRS/BRZ? AceNiNe Scion FR-S / Toyota 86 GT86 General Forum 5 05-19-2013 07:06 PM
So what mileage are you getting? carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 76 01-22-2013 04:23 PM
Gas Mileage frosty86 Hawaii 12 10-09-2012 04:56 AM
How much mileage do you have on your car now? iff2mastamatt Other Vehicles & General Automotive Discussions 82 01-11-2012 01:48 AM
