Old 09-19-2016, 08:40 AM   #1
bleox
Drives: 2015 Subaru brz
Rear lca for autocross?
Okay so I called an alignment shop in Glendora CA and they recommend me the spl lca... But im curious if their is a cheaper alternative.... and clearly stated that he didn't recommend the spc lca any opinions?! Thanks in advance
bleox is offline   Reply With Quote
Old 09-19-2016, 09:21 AM   #2
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
What class are you running in? Some LCA's aren't legal for certain classes.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
whataboutbob (09-19-2016)
Old 09-19-2016, 09:42 AM   #3
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
I don't believe there are any recalls or major issues with SPC's rear lower control arm. Plenty of serious drivers use them.
It's designed similar to the OE arm with a slot and eccentric bolt. Personally, I like the design for daily drivers and salty environments. Rod ends (heim joints) are tough to do engineer properly/reliably (just check Velox's development thread).
Also, if you need more than 2 degrees of adjustability in either direction (beyond the natural camber that you get from lowering the car), the SPC arms aren't the best choice. Whiteline is good for ~2.5 degrees. If you plan to have limited travel, go with Stance or Voodoo13. Otherwise, SPL, ISC, Velox, and Cusco are great options.
Since your title refers to autocross... SCCA C-street doesn't allow this modification, but STX class does (as long as you're using a rubber/urethane outer bushing). I can't speak for other autocross organizations.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 09-19-2016, 09:56 AM   #4
smg1138
smg1138's Avatar
I use the newest Whiteline LCA and have no complaints. It's basically the same as the SPC, but the bushing is legal for STX class. It does everything I need it to do.
Old 09-19-2016, 09:56 AM   #5
wparsons
wparsons's Avatar
I think SPC and Racer X (if you get the bushing instead of the heim joint) are the only STX legal LCA's?
flickr
Old 09-19-2016, 10:38 AM   #6
strat61caster
strat61caster's Avatar
Velox has a urethane rod end for stx legality. And iirc there's one more, maybe rsr that has the right rod end.
The off the shelf SPC lca isn't technically legal as it's a lubricated spherical bearing in a rubber joint and it has to be pressed out and replaced with a legal bushing. Only a pedant would call you on it though, go for it and spend the money to replace it if you start gunning for nationals.
ineedyourdiddly
Old 09-19-2016, 10:49 AM   #7
bleox
I'm running stx on scca .... And no I don't need a crazy amount of camber... It was what ever the shop needed for camber while they did their tune....
Old 09-19-2016, 01:36 PM   #8
bleox
So to stay in stx I need a urethane style rod end?
Old 09-19-2016, 01:57 PM   #9
whataboutbob
AutoX-10/10ths every run
Read up on the rules here: http://cdn.growassets.net/user_files...pdf?1458856541
You can't have spherical in STX. There are also other constraints in the rules.
Build thread:Here
Old 09-19-2016, 02:20 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The list here denotes stx legal LCAs
http://www.ft86club.com/forums/showthread.php?t=103609
bleox (09-19-2016)
Old 09-19-2016, 02:31 PM   #11
bleox
Beautiful post all the info I need... like how u listed the ones that are stx compatible
The Following User Says Thank You to bleox For This Useful Post:
finch1750 (09-19-2016)
Old 04-01-2018, 08:56 AM   #12
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Old thread, but any restrictions on LCA for SM class? That's my eventual destination :-)
BR-ZED is offline   Reply With Quote
Old 04-02-2018, 03:30 PM   #13
whataboutbob
I'd advise you to read the rules here: https://www.scca.com/downloads/40392...duced/download
The SM rules start on page 180.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Shinchu (04-03-2018)
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
NER Autocross 6/2 48Spoons New England 1 06-01-2013 02:14 PM
What is better for autocross? Toyota GT 86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-28-2013 05:29 AM
1st Autocross w/ my FR-S MarkRacerX FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 06-24-2012 10:55 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
