Old 09-16-2016, 09:20 AM   #1
BrunoCr7
Drives: 2017 Subaru BRZ
2017 BRZ 6th feels stiff
Just got my brand new 2017 BRZ and I was just working on getting used to the gears and where they are so I had the car off and the clutch pressed down and I started going from 1st to 6th and I noticed when I got to 6th, putting it into 6th felt a little stiff and clunky, is that normal?
BrunoCr7 is offline   Reply With Quote
Old 09-16-2016, 09:23 AM   #2
bababooey
Drives: BRZ SWP Limited -6MT
new car, give it a few hunder/ thousand miles to break in. it could also very well be that the engine isnt on.
Old 09-16-2016, 10:19 AM   #3
Trust86
Drives: 2016 Halo FRS
+1 for engine being off
Trust86 is offline   Reply With Quote
Old 09-16-2016, 11:07 AM   #4
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Pretty standard symptoms. It's easy to forget that most cars these days don't have a direct mechanical linkage to the transmission like ours do which is what makes shifting feel so snappy and crisp.
Once it's broken in and when all the fluid are up to tempt, it's probably one of the best feeling transmissions out there. Sure some of the older versions (mine included) have some synchro issues particularly 4th to 5th, but I believe the revised transmissions in the MY2017 they've really beefed up the internals so hopefully you won't run into any of that later on.
While you're at it, if you subscribe to the "change engine oil at 1k mile" break-in theory, you should swap out the M/T fluid as well. Motul seems to be a forum favorite and it should make shifting buttery smooth. I just wish I had done the same much earlier on as it could've saved me some headaches down the road.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 09-16-2016, 09:49 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
The car never became alive until 3000 miles. It felt tight and weird. The factory breakin oil in the car was also making it rev super slow.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-17-2016, 03:33 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
yup, like @Manic said swap the trans/diff fluid soonish-maybe between 3 and 5k miles?
Just don't wait until the "recommended" mileage lol
Old 09-19-2016, 05:13 AM   #7
projectXTR
Drives: Sterling Silver BRZ
Start the engine.
Let it idle and warm up in neutral.
As soon as the RPM drops to around or below 1000 RPM you're good to go.
Shifts are way smoother compared to just starting the car and taking off immediately.
projectXTR is offline   Reply With Quote
Old 09-19-2016, 05:25 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
No need to change the trans/diff fluids. The car is just in the break-in period and everything will smooth out gradually. Consult your dealer for the fluid change intervals.
Old 09-19-2016, 05:51 AM   #9
For crying out loud guys did only a couple of you read the whole post? The freakin' car was off. "Wait and let it break in" and "change the oil right away"? Really?
The gear are meant to be shifted when the syncros are spinning. ^h gear is meant to be spinning the fastest. Sitting in the shut off car making vroooom noises and shifting gears is not driving.
Why do so many want to "fix" things that are not broke all the time?
Old 09-19-2016, 06:47 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I was doing lately an installation and had to switch the gear on 6th while the engine was off. I didn't notice any stiffness. In general the gear box in this car needs its time and I wouldn't worry too much.
Old 09-19-2016, 09:01 AM   #11
radroach
Drives: car
My 6th gear has always felt a little longer, notchier, and slower to get into. No problems getting into it though, I just don't throw it in hard since its just a cruising gear.
Old 09-19-2016, 09:56 AM   #12
Lantana frs
Drives: 13 frs red
The gears like to be spinning when asked to engage one another.
Lantana frs is offline   Reply With Quote
Old 09-19-2016, 12:27 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
For crying out loud...
Maybe OP was coasting.
Old 09-19-2016, 01:11 PM   #14
strat61caster
strat61caster's Avatar
My two cents; I like how my tranny feels better with 52,000 miles on it than it did with 52 miles on it.
ineedyourdiddly
BC Coilovers - How stiff is stiff? XxFooManDrewxX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 09-24-2015 12:53 PM
MT: 1st and 2nd stiff when cold Harvey Scion FR-S / Toyota 86 GT86 General Forum 7 05-27-2014 06:50 AM
stiff stearing? Jeong Issues | Warranty | Recalls / TSB 5 11-18-2013 12:28 PM
18's or 19's ... What looks and feels best on FR-S. Jon1084 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 65 07-19-2013 06:42 PM
1st gear in FRS a little stiff? Brody602 Engine, Exhaust, Transmission 4 04-18-2013 08:46 PM
