Old 04-18-2013, 08:13 PM   #1
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
1st gear in FRS a little stiff?
Hi,
My 6MT FR-S has ~900 miles (1400km's) and I find that it requires quite a bit of force when attempting to put it into first gear/reverse, yes I'm pushing the clutch all the way to floor lol, just wondering if this is normal or not?
Thanks
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-18-2013, 08:17 PM   #2
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
You can change your transmission fluid or you can drive it and it'll smooth out itself eventually.
Books is offline   Reply With Quote
Old 04-18-2013, 08:18 PM   #3
YangerD
YangerD's Avatar
Drives: 2017 Toyota 86
I would say it shouldn't be hard. Does this only happen when the car is cold or at all times?
YangerD is offline   Reply With Quote
Old 04-18-2013, 08:22 PM   #4
Brody602
Drift King
Brody602's Avatar
Come to think of it, it does seem to be stiffer when it's cold, but it's still fairly stiff when the car is fully warmed up, I'm expecting it maybe to loosen up a bit once the car gets more mileage, most of my mileage is 80% highway so not too much shifting has been done.
Old 04-18-2013, 08:46 PM   #5
FR-S Matt
I hit the 5k mark and mine still is a bit rough while cold. Sometimes I have to double clutch when I first start the car early in the morning to get it in reverse. It loosens as it gets warmer. From what I have seen, Pentosin has helped others fix this issue with the cold starts and while warm with the tough reverse, and tough 2nd gear shift while cold.
I have 0 problems once the car is warm and the fluids reach their operating temp. All gears are easy except the 1st to 2nd gear shift can be a little rough sometimes.
Stiff 2nd Gear actuation when cold on manual 6 Speed of FRS/BRZ? There's a reason! Moto-P Scion FR-S / Toyota 86 GT86 General Forum 129 09-19-2015 04:49 PM
Stiff coilover options? YDNA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-05-2013 09:33 AM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
