Old 05-26-2014, 06:04 AM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
MT: 1st and 2nd stiff when cold
Hi,
I find it hard to get into 1st and 2nd when the car is totally cold (first start in the morning, around 14°C these days), after a minute and a few hundred meters it gets nice and smooth. This is the case either upshifting (neutral to 1st and 1st to 2nd) or downshifting (3rd to 2nd or 2nd to 1st). Te other gears seem fine.
I feel this when setting of in the morning, engaging 1st gear isn't that smooth, and then shifting the 2nd is pretty sticky... then at first stop sign going back down 3rd->2nd->1st is pretty sticky too... then after a little time it all gets smooth.
The car has 1000KM now
Harvey is offline   Reply With Quote
Old 05-26-2014, 12:50 PM   #2
zooki
Drives: waiting on a 2021...
So....is there a question in here? Or just a statement? A lot of people have changed their teams fluid out for improved results. I run Pentosin MTF2 myself, and others run Motul, or Amsoil, or Redline, among others.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
aristo (05-26-2014)
Old 05-26-2014, 04:33 PM   #3
Harvey
I guess I forgot the question(s)... it was: is this normal? Will it stop when everything breaks in (a few thousand KMs or so)? Have others noticed this or is it just mine? People new cars and MTs can easily answer the last....
Old 05-26-2014, 04:56 PM   #4
strat61caster
strat61caster's Avatar
1. Yes
2. It should get better as it breaks in
3. Very common
http://lmgtfy.com/?q=ft86+club+stiff...n+first+second
ineedyourdiddly
Old 05-26-2014, 05:39 PM   #5
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I switched to Motul Gear 300. It is a bit better but still sticky when cold. I live with it as I know it is very common.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 05-26-2014, 07:27 PM   #6
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Completely normal, try changing to one of the fluids mentioned above. In the short term though, you could try my current solution:
http://www.ft86club.com/forums/showthread.php?t=60136
Old 05-27-2014, 04:07 AM   #7
Harvey
Great, this all makes me happy, nothing wrong with mine, and in my case it's very acceptable... in fact, reading these threads gives me the impression that some are pretty worse off (but on the other hand it's not very cold these days, I'll see this winter if I end up having to skip 2nd alltogether like some in the thread)
Old 05-27-2014, 06:50 AM   #8
LordKain
LordKain's Avatar
Drives: 86 GTS
I came from a MT 370Z and it was the same, I used to double clutch while the fluid is cold. I found this helped a lot, just my 2cents worth.
LordKain is offline   Reply With Quote
Stiff 2nd Gear actuation when cold on manual 6 Speed of FRS/BRZ? There's a reason! Moto-P Scion FR-S / Toyota 86 GT86 General Forum 129 09-19-2015 04:49 PM
stiff stearing? Jeong Issues | Warranty | Recalls / TSB 5 11-18-2013 12:28 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
1st gear in FRS a little stiff? Brody602 Engine, Exhaust, Transmission 4 04-18-2013 08:46 PM
Stiff coilover options? YDNA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-05-2013 09:33 AM
