Old 09-03-2016, 12:34 PM   #1
pooch
pooch's Avatar
Drives: 2013 Scion FR-S (M/T)
Oil change and filter question
I'm sorry, I may be panicking a little bit, and this might be in here somewhere, but I just changed my oil myself for the first time after getting the car, and I replaced the OEM oil filter with a Greddy oil filter and noticed that there is a hole outside of the sealing area. Is this just a drain hole? Or is this supposed to be covered? Thanks so much...
pooch is offline   Reply With Quote
Old 09-03-2016, 01:27 PM   #2
humfrz
It's just the drain hole.
Some filters cover it up more.
humfrz
Old 09-03-2016, 03:00 PM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Why not using an OEM oil filter?
Old 09-03-2016, 03:47 PM   #4
pooch
pooch's Avatar
To be super tuner jdm man! Na, but seriously no particular reason, to be different I suppose, plus got my magnetic drain plug from the same person so this is what they had and I just went with it, see how it does..
Old 09-03-2016, 11:28 PM   #5
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Use OEM subaru Filter. cause racecar man. Its just there no pressure or any oil should be in it. I clean mine after ever change that way if there is a seal leak ill know it was clean before hand. even with OEM filter from suba the crevice is still visible.
tofurun is offline   Reply With Quote
Old 09-03-2016, 11:40 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
I don't think it's even a drain hole. I don't know what it's for but it's just a divot. Maybe it started out in the design as a drain hole but after the dies were made they decided it wasn't necessary?
Old 09-03-2016, 11:56 PM   #7
tofurun
tofurun's Avatar
I dont think its a drain hole either because if i remember correctly the seal part is actually raised and if it did drain the oil pressure would cause oil to spew out of it. I think its just there as a place to hold the majority of the oil so it doesnt run circles. Or maybe it is there so it all collects in one place so you can clean it up easier during changes. IDK im rlly just talking out my butt at this point.
Old 09-04-2016, 12:15 AM   #8
Ultramaroon
not playing cards
It's there so I have to clean it with a q-tip every time I change the oil. -___-
Old 09-04-2016, 01:57 AM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Wrong filter bro. Oem brz filter is designed for this car the one you have is for Impreza/older WRX
Gotta be 100%JDM man.
Jokes aside
I always wanna ask.... How different is a normal filter compare to a errr..."high performance"filter? >_>
I guess I can google...
Old 09-04-2016, 02:04 AM   #10
humfrz
Oh my, @pooch ..... @Ultramaroon and @tofurun are correct, it is NOT a drain hole.
My bad ......
However, I suspect it is a "vestigial" drain hole ......
humfrz
Old 09-04-2016, 08:49 AM   #11
gravitylover
I always get my filter from a dealer and they always ask for the vin #. Last time it was explained to me that the filter changed a few times and there are differences based on production dates. The woman behind the counter even showed me three different ones and while they looked essentially the same there were noticeable differences in diameter that I wouldn't have realized without them being side by side. Another thing that I realized was the older ones are packaged with a new crush washer and the newer ones aren't.
Oil filter part number change, both #s deconstructed. Calum Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 03-05-2023 01:02 PM
Air Filter Change X Factor Engine, Exhaust, Transmission 15 08-31-2016 11:50 PM
DIY Change in cabin air filter VeganGirl DIY (Do-It-Yourself) Guides 11 06-06-2016 12:42 PM
Stupid Question: When to change OEM intake filter? m.wood0213 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-17-2014 07:35 AM
How to just change the oil filter, not the oil? GMT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 12-10-2012 02:07 AM
