Drives: 86 GTS
[ame="https://www.youtube.com/watch?v=hQH3ZgVeHho"]Öhlins DFV knocking noise - YouTube[/ame]
this is the description under the video: Car: Toyota 86 Shocks : Öhlins Road and Track DFV SUSMP20 F:4kg/R:3kg Camber Tops: Raceseng CasCam Endlinks: Whiteline Tyres: Potenza RE003 (30PSI cold) Preload: F: 32mm (recommended setting) This is a nightmare!!! Absolutely killing me whenever i drive the car. The noise is driving me nuts. Cannot live with it. Have been spending all of my dayoffs since the initial installation, trying all sort of ways to figure out the source of knocking noise over sharp bumps in low speed from front struts. I can literally hear EVERY bump on the road through the cabin. Replaced another set of camber tops, another set of lower balljoints and swaybar endlinks. Changed the upper spring perch to Raceseng bearing perch to eliminate spring binding. (Recommend preload is 32mm from free length) I'm sure the noise is coming from inside of dampers. Either running Whiteline or OEM endlinks as well i disconnected them, the noise still exist. I don't believe that's the way DFV works. Whenever i try to push the car it makes me worry and panic it could make further damage. Emailed to Öhlins Sweden, they even sent another pair of front struts as replacement. But it's not making any difference. Super frustrating and annoying. Been spending lots of time and money just on this single issue. Had very high expectation on Öhlins but not expecting coilovers worth $3200AUD makes noise. Noise started from initial installation. Isn't going away on any damper setting. If anyone have experienced similar issue please share. PS: May have to crank up the volume to hear the knocking noise. Microphone is mounted inside of cabin on the dashboard. Long story short, got a set of MP20, already found knocking noise right after initial installation. After some researching, i don't think it's something normal. Contacted Ohlins Sweden, they immediately sent me replacement. But the noise was exactly same as original ones. I thougth it's the camber tops. Then i got a set of Raceseng Cascam tops. the noise didn't going away. Ohlins sent me 'another' pair of front dampers. Alright this is the second pair, the noise is slight quieter but it's still there. I can definitely hear from cabin. Before the sent the second replacement, they confirmed there's no noise with those campers. (well it's not true) the noise is just not as bad as original and first replacement. Have asked lots of ppl experienced similar noise on their coilovers. most of them found the top nuts were loose or the 4 bolts around the shaft not installed properly. I have checked dozen times. that's not the cause in my case. I have done the followings: torqued the top nut to recommended spec disconnected swaybar, removed endlinks torqued every single bolts attached to the damper checked the tower braces are tighten replaced lower ball joints At the end i swapped a pair of no brand coilovers from my friend and the noise gone. So i'm 100% sure the noise is coming from dampers itself. I'm appreciated the warranty claim from Ohlins Sweden, but that's doesn't solve the problem. Super frustrating and annoyed whenever i drive the car. Been spending too much time and money just to find out the problem. Last edited by teppei; 09-02-2016 at 08:52 AM. Reason: adding description |
| The Following User Says Thank You to teppei For This Useful Post: | kevaughan (10-23-2023) |
#2 | |
Drives: 2005 Toyota Camry
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | ajc209 (10-20-2016) |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
My friend has these installed with another company's top camber plates, and they are clunky/noisy as well. It's the camber plates in his though. They use spherical balls with no bushing, and if you take the weight off the wheel by jacking the car up off the ground, you can move the top of the shock and feel/hear it moving just a micro millimeter inside the camber plate. Good luck with yours! :/
Dismember
Drives: 2013 Red Scion FR-S
My God! You're driving on the wrong side of the road!
Dismember
I spent the entire video searching for utes. I only saw one. WTF? You call that Oz?
I suggest you life the car, take the wheel off, and shake like mad, trying to get something to move. Something IS moving.
| The Following 2 Users Say Thank You to EAGLE5 For This Useful Post: | kevaughan (10-23-2023), strat61caster (09-02-2016) |
BTW I listened to your video.
The sound is not coming from the shock, it's coming from your upper mounts. An improperly sized shock nut can do that. So can one that is not tightened properly. I've heard this noise on various cars over the past 20 years. The solution is always the same. Pillowball upper mount is loose, from one of the two reasons above. -alex |
| The Following 2 Users Say Thank You to mav1178 For This Useful Post: | kevaughan (10-23-2023), strat61caster (09-02-2016) |
Are you using the Öhlins or Raceseng spring perch? It's important that the bushing between the shaft, upper mount, and perch is properly sized. Raceseng makes a number of bushings to accommodate different coilovers - it's possible that when you ordered your Raceseng CasCam plates you selected the incorrect size bushing, which may be causing the noise. It's relatively easy to verify.
#8 | |
Drives: 86 GTS
| The Following User Says Thank You to teppei For This Useful Post: | RJasonKlein (09-02-2016) |
#9 | |
Drives: 86 GTS
#10 |
Drives: '15 BRZ RA
Did you try the OEM tops?
#11 |
Drives: 2014 BRZ
The probability of the the dampers themselves making a knocking sound are is probably -1... It is almost certainly in how the Ohlin's mate to the top mount (as other have noted).
| The Following User Says Thank You to Sleepless For This Useful Post: | wparsons (09-02-2016) |
#12 |
Drives: '15 BRZ RA
Apart from the noise, how do they feel?
#13 |
Drives: 86
Best way to know, put back the OEM tops.
The MP20 can re-use the OEM rubber tops. If noise goes away, its the raceseng plates. If it still persist, swap out the endlinks to stock ones, rinse and repeat. Do this until the only factor left, is the dampers... |
#14 |
Drives: slow poke
I'm running CL Brakes and the way they are made, they have some up and down play, and sometimes make noise on bumps. It also makes noise when I reverse as the pads are getting picked up by the rotor and fall back down.
Maybe this is your issue? Andy
follow me on instagram:@efi.andy
| Tags |
| coilovers, knocking noise, ohlins |
| Idle knocking noise | Kostamojen | Issues | Warranty | Recalls / TSB | 33 | 04-20-2018 01:09 PM |
| Knocking Noise Near Driver Seat | N1rve | Issues | Warranty | Recalls / TSB | 21 | 09-21-2016 10:36 AM |
| My ohlins starts making wired noise~~~~HELP!!!!!! | kkman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 04-01-2016 02:51 PM |
| My ohlins warranty problem!!!!!!see what Ohlins China replies!!!!!!!!!!!!!!!!!!!!!!!! | kkman | User/Vendor/Sponsor Reviews, Feedback, Comments | 18 | 03-31-2016 10:59 AM |
| Knocking noise from LSD after FD swap | Toyota86.ir | Engine, Exhaust, Transmission | 15 | 11-08-2015 03:02 AM |
