Drives: 2019 BMW ///M4
Knocking Noise Near Driver Seat
I've been hearing a knocking noise when I come to a complete stop or taking off from a complete stop near my driver seat or under it. I looked under and there's nothing there. Anyone else have experience with this? Things to check? I tried lubing the rails and nothing happens.
I can jump up and down in my seat and rock it and sometimes it will make that knock noise.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Well, @N1rve , first thing I would try, is to look under the seat and tighten any bolts I could see and get to.
If that didn't stop the knocking noise, I'd be tempted to take the seat completely out of the car and check the adjusting mechanisms for lose, broken or warn parts and make sure all bolts/nuts were tight. Don't forget to check the return springs for the mechanisms (if there are any) and while the seat is out, check to make sure there isn't a lose, broken or out of place seat cushion spring (if these seats have them). That ought to take care of your Saturday morning ..... ![]() humfrz |
hey you, yeah you <3
Drives: 2014 37J FR-S
Lose panel below the car?
| The Following User Says Thank You to Packofcrows For This Useful Post: | Norville Rogers (09-14-2016) |
Gremlins?
| The Following User Says Thank You to Ashikabi For This Useful Post: | SlammedSilly (09-21-2016) |
#6 | |
Tripple checked that forsure especially since I was wary if I touched any other panels when I installed my perrin exhaust. God damn Gremlins.
N1rve
| The Following User Says Thank You to N1rve For This Useful Post: | humfrz (01-23-2016) |
Drives: Full race 4cyl boxer
You don't have any type of shifter modification?
Panels may seem firm but under wind pressure may shake/vibrate.
Just my .02C not Canadian.
Nope. Drive an automatic.
N1rve
#10 |
Took the car to the dealer to look into this noise issue as well. Stand by for updates tomorrow!
N1rve
#11 | |
Drives: 2013 SWP 6MT BRZ Limited
I have my car for 3 years now, and my driver seat has started making the knocking noises recently, too. Just like how you described it, the noise is usually induced when taking off from a complete stop. |
#12 |
not playing cards
Rear axle nut?
#13 | |
The dealer found nothing, I took it to an independent mechanic who road with me and found out it's a NATURAL noise of the car. It's the reverse lockout of the transmission clicking into place. For some odd reason my car is very loud and the way to solve it is to put paste lube directly onto the reverse lockout and made it less noisy. I still hear a slight tapping but it's significantly lower in volume. Originally checked the exhaust, seat rails, and E-brake and those were not the cause.
N1rve
| The Following 4 Users Say Thank You to N1rve For This Useful Post: |
#14 |
| Knocking noise from LSD after FD swap | Toyota86.ir | Engine, Exhaust, Transmission | 15 | 11-08-2015 03:02 AM |
| Knocking from Driver side | Wilso | Issues | Warranty | Recalls / TSB | 6 | 05-22-2015 09:46 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
| Driver Seat Article... | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-15-2012 09:06 PM |
