Old 06-17-2016, 02:44 PM   #1
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Idle knocking noise
Ive been having this knocking noise occasionally at idle and now lately Ive had some idle issues where the car feels like it wants to stall at a stop. No check engine lights and stock exhaust currently with stock ecu tune.
[ame]http://youtu.be/yQNlADRwSpY[/ame]
[ame]http://youtu.be/kCdP8sJ7oJc[/ame]
Anyone have something similiar or knoe what this is?
Kostamojen is offline   Reply With Quote
Old 06-17-2016, 03:59 PM   #2
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Something doesnt sound right. Dealer visit...
SpectreRT is offline   Reply With Quote
Old 06-17-2016, 05:14 PM   #3
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
That doesn't sound good. Almost like a bad rod bearing. Defo visit the dealer asap.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz
Romanov is offline   Reply With Quote
Old 06-17-2016, 05:34 PM   #4
Kostamojen
Also note:
It doesn't occur when the vehicle is in gear with clutch engaged, but the car does have a slightly rough time if you start slowly in first gear. Also doesn't occur when pressing the clutch pedal down.
Old 06-17-2016, 07:27 PM   #5
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Mine has been making this noise since it was brand new. It was only noticeable when I tap the gas pedal like in your first video. After the transmission oil change, it got louder and I can hear it even when it's idling. The noise at idle goes away after about 20 mins of driving. Also goes away when the clutch pedal is depressed like you mentioned. I've seen multiple threads about this noise. I wouldn't worry. Mine is louder than yours.
Sigh-on-Rice is offline   Reply With Quote
Old 06-17-2016, 08:06 PM   #6
humfrz
Well, I'll go along with the "something ain't right" crowd.....
It could be an exhaust leak
could be something lose in the valve train
could be something is lose in the area of the clutch
Anyways, I'd suggest you get it tended to .......
humfrz
Old 06-17-2016, 08:11 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Grab a small section of garden hose and listen at each cylinder, see if the sound is localized to one cylinder or if it maybe is coming from somewhere else. Is it top end or bottom end?
That does not sound good.
Old 06-18-2016, 12:22 AM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
That ain't right. ...really ain't right. ...and it's all 4. I can hear that in your first clip. I think it's the trans or clutch.
Old 06-18-2016, 01:54 PM   #9
Sigh-on-Rice
Now I'm worried.
Old 06-18-2016, 02:30 PM   #10
Ultramaroon
not playing cards
Originally Posted by Sigh-on-Rice View Post
Now I'm worried.
I don't think it's the engine because I hear it on the power stroke of all 4 cylinders. Also, dead giveaway, Kosta says he doesn't hear it when the clutch pedal is depressed which, I will emphasize for the sake of clarity, is when the clutch is disengaged.
We've seen some stock friction disks frag due to poor quality control where they're riveted together. I'm leaning towards this one being on its way out.
When my trans is cold, I do hear a tiny bit of rumble as the power stroke jiggles all the disengaged gears. That's typical and is called "neutral rollover."
If the sound you hear has existed since new and, this is key, has not changed, I wouldn't sweat it.
Old 06-18-2016, 10:19 PM   #11
Kostamojen
It hasn't existed since new. I did have the throw out bearing and clutch disc replaced under warranty a couple months ago.
More info:
The idle issue is present even after driving the car for a couple issue, IE the car drops revs when at a light and almost wants to stall but doesn't quite stall. Wondering if this is a separate issue from the knocking, which I didn't hear today.
Old 06-18-2016, 10:38 PM   #12
Ultramaroon
not playing cards
More info:
That is interesting to hear about the recent work. I suspect a correlation and recommend taking it back to where you had the work done. Like @humfrz said, it sounds like something is loose under that bell housing.
A little infonugget. I have my clutch interlock switch defeated so I don't have to press it when starting the engine. If I time disengaging the starter with goosing the throttle just right, I can get the exact same idle knocking sound you have but it lasts only a split second way below 500 RPM. For me it's the gears rattling with each ignition pulse.
I see your tach. It should not be happening at normal idle RPM, at least not with a stock flywheel.
I could see the idle issue being related if, God forbid, your flywheel was actually coming loose. The crankshaft position scale is back there. I don't know. That seems like a real stretch, though.
Old 06-18-2016, 10:52 PM   #13
humfrz
More info:
Tell us about WHY the clutch and TOB were replaced ...... what was the car doing (or not doing) .. ??
Was the pressure plate replaced.. ?? How about the clutch fork .. ??
As far as the idle dance, that's most likely a "tuning" thing.
Yep, ol @Ultramaroon and I "hear" it as a "something under the bell housing thing" .......therefore, ...... it must be so .....
humfrz
Old 06-18-2016, 11:17 PM   #14
Kostamojen
Standard squeaky throwout bearing problem. Clutch fork was not replaced but the pressure plate was.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Knocking Noise Near Driver Seat N1rve Issues | Warranty | Recalls / TSB 21 09-21-2016 10:36 AM
Knocking noise from LSD after FD swap Toyota86.ir Engine, Exhaust, Transmission 15 11-08-2015 03:02 AM
Noise when idle (not Crickets) hanabie Issues | Warranty | Recalls / TSB 8 10-18-2013 08:58 PM
Idle Sound Click/Noise FRS_Jack Issues | Warranty | Recalls / TSB 4 10-13-2013 09:26 PM
