Old 08-23-2016, 03:16 AM   #1
brzfl
Drives: 2015 CWP BRZ Limited
Horrible Rubbing with 265 MPSS
Hey guys I'm running 265 MPSS all around on a 18x9.5 et38 wheel and I'm getting horrible rubbing on both the back and the front. My camber in the front is -2 and -1.8 in the rear without LCAs. The front is straightforward and I will probably just raise it a little and dial in the camber. But to fix this rubbing issue in the back, should I raise the car? My only gripe with that is the rear wheels would be poking then as I can't add more camber. So should I lower the car in the rear for more camber to tuck the wheels inside the arches away from the fender
To add, I've read that the rears rub on the fender tab and eventually rub out but it's been over a month now on these tires.
Any help would be appreciated!! Thanks guys
Also yes I am on coilovers.
For reference, here's a current pic of the car:
brzfl is offline   Reply With Quote
Old 08-23-2016, 03:19 AM   #2
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
No fix, time to go wide body in the rear. 😂
Old 08-23-2016, 03:25 AM   #3
brzfl
Originally Posted by chaoskaze View Post
No fix, time to go wide body in the rear. ��
I guess the car is totalled
Old 08-23-2016, 09:46 AM   #4
driggity
Drives: Silver Coupe with a Boxer
How much are you lowered and where is the rubbing actually happening?
driggity is offline   Reply With Quote
Old 08-23-2016, 11:03 AM   #5
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Where is it rubbing?
The coilover? Dial back the camber, or add a 3mm spacer.
The fender? Get the fenders rolled.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-23-2016, 11:07 AM   #6
gramicci101
Off Topic
This thread is a wealth of information regarding fitting 255+ tires under your car.
http://www.ft86club.com/forums/showthread.php?t=41083
Old 08-23-2016, 12:15 PM   #7
ModBargains.com
ModBargains.com's Avatar
even 255 is pushing it with the pss tires.
we stock these tires and although they are an amazing tire, they do run a little wider than others in the same "size".
18x9.5 +38 usually my customers will run a 245 set up if they want to completely avoid rubbing or 255 if they are trying to max out what will fit, 265 i see rubbing all day.
ModBargains.com is offline   Reply With Quote
Old 08-23-2016, 12:19 PM   #8
brzfl
It's rubbing on the little lip inside the fender, I'll update with pics in a minute.
Old 08-23-2016, 12:20 PM   #9
brzfl
Yeah as of right now, the car is pretty much undriveable
Old 08-23-2016, 01:32 PM   #10
JazzleSAURUS
Get your fenders rolled.
Old 08-23-2016, 02:16 PM   #11
8R6
8R6's Avatar
Drives: FRS
what this guy said
8R6 is offline   Reply With Quote
Old 08-23-2016, 02:32 PM   #12
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Guy who did my fender roll cut these lips off, should solve the problem if that's the only place your rubbing.
VIP BRZ is offline   Reply With Quote
Old 08-23-2016, 02:51 PM   #13
brzfl
Yeah looks like I'm gonna have to do some variation of rolling and cutting the lips, scared though because I have a 500 mile drive today with luggage in the car, dont want my tires to get ruined or blow out
Old 08-23-2016, 02:56 PM   #14
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
...the car is pretty much undriveable...
... I have a 500 mile drive today with luggage in the car...
this doesn't sound like a good idea
asdf is offline   Reply With Quote
Horrible bucking and shutter after clutch install Scikotic Engine, Exhaust, Transmission 32 07-12-2016 08:10 PM
First post here: horrible story wood86 Scion FR-S / Toyota 86 GT86 General Forum 31 04-06-2015 12:13 PM
SEATBELTS horrible retractor BRZ_Lawyer Issues | Warranty | Recalls / TSB 15 01-04-2014 06:38 PM
Horrible Stock header? brichard0625 Engine, Exhaust, Transmission 5 12-03-2012 11:25 AM
Horrible dilemma Double4Free Scion FR-S / Toyota 86 GT86 General Forum 29 11-14-2012 08:16 PM
