Old 12-29-2013, 09:57 PM   #1
BRZ_Lawyer
Hardworking
BRZ_Lawyer's Avatar
Drives: 2013 Subaru Brz, 2013 C300 4Matic
SEATBELTS horrible retractor
I am getting extremely frustrated with my drivers side seatbelt. On more than one occasion the seatbelt has not retracted well enough and I have found myself shutting the door with the seatbelt dangling outside, or I have shut the door on the metal belt part itself!!!
Has anyone else been faced with this issue?
Lawyer in NJ and Pennsylvania.
My BRZ gets me to court quick!
2013 WRB BRZ Limited
2013 C300 4Matic
Septa, NJtransit, MTA
BRZ_Lawyer is offline   Reply With Quote
Old 12-29-2013, 10:01 PM   #2
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Mine are quite the opposite, I find it retracts almost to well. If I'm not careful the buckle goes flying upward and hits the window, always worried about scratches or cracked glass.
FiRStsc10n is offline   Reply With Quote
Old 12-29-2013, 10:03 PM   #3
whaap
whaap's Avatar
Mine work fine. You have what is called a warranty problem.
whaap is offline   Reply With Quote
Old 12-29-2013, 10:36 PM   #4
BRZ_Lawyer
Hardworking
BRZ_Lawyer's Avatar
how long have you had the car? I will be bring this to the dealer's attention. by the way any tips on ordering a different seatbelt color? red perhaps?
2013 C300 4Matic
Old 12-29-2013, 10:42 PM   #5
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
the only seat belt problem i have is the rear passenger one. It doesn't fully retract and when the window's open, it flaps like crazy
bkblitzed is offline   Reply With Quote
Old 12-29-2013, 10:55 PM   #6
whaap
whaap's Avatar
I bought my car in Sept, 2012 and have 14,000 miles on it. The car only comes with one color interior.
Old 12-29-2013, 11:34 PM   #7
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Is the passenger side the same way?
campy is offline   Reply With Quote
Old 12-30-2013, 01:49 AM   #8
humfrz
Not with my FR-S, but with another car (Miata).
What you might try is to clean the seatbelt with warm soapy water (to make sure there isn't something gummy on it which would slow it down going through the slide).
Also, you could check the slide for any obstructions.
Or .... take it back to the dealer for replacement.
humfrz
Old 12-30-2013, 06:00 AM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I'd take it to the dealer. You bought a new car with a warranty to avoid any issues. You didn't buy a new car to have a warranty sit and expire and fix all the issues yourself.
Old 12-31-2013, 08:50 AM   #10
BRZ_Lawyer
Hardworking
BRZ_Lawyer's Avatar
Nope only the driver side
Sent from my Nexus 4 using Tapatalk
2013 C300 4Matic
Old 12-31-2013, 03:01 PM   #11
Tromatic
Mine is weak as well. I can't think of a car I've ever had that did not have a weak retractor. However, unbuckle, lift buckle up and to the rear over your shoulder, problem solved.
Tromatic is offline   Reply With Quote
Old 01-02-2014, 09:49 AM   #12
jaff87
Guest
Posts: n/a
I've had this in every dealers I've worked in various brands same problem same solution. Try pulling it all the way out and go at it with a vacuum cleaner if not go at it with a interior shampoo. Also thoroughly clean the guide on the b pillar. It's worse on black or grey belts because you don't realise how mucky they get. Particularly if you share the car with a girl as they tend to have residue of face creams and make up on their hands and neck that the belts pick up. Those are also what rotts cheap steering wheel leather making them melt/blister and peel.
Old 01-02-2014, 10:53 AM   #13
SteveGrillo
Drives: Brz
I wouldn't do anything to it other than take it to the dealer for replacement. And FYI it doesn't matter how many miles/years you have on it. I believe seatbelts are lifetime warrantee devices.
SteveGrillo is offline   Reply With Quote
Old 01-02-2014, 01:35 PM   #14
Tromatic
I wonder if seat belt retractors in US models are loose to fit the typical American tummy without being too snug? OP, in order to comply with the forum SOP you need to demand a new car.
brz, fr-s, retractor, seatbelt
WTB: Seatbelts and MAF sensor Hilux Want-To-Buy Requests 0 11-20-2013 07:15 PM
Horrible Stock header? brichard0625 Engine, Exhaust, Transmission 5 12-03-2012 11:25 AM
Horrible dilemma Double4Free Scion FR-S / Toyota 86 GT86 General Forum 29 11-14-2012 08:16 PM
Cold morning and horrible grinding/screeching sound Books Issues | Warranty | Recalls / TSB 1 11-14-2012 02:18 PM
Backseat buzzing solved (Seat belt retractor?) enivid Issues | Warranty | Recalls / TSB 1 10-05-2012 11:51 AM
