Old 08-15-2016, 05:18 PM   #1
swarb
Long term E85 use and Lubes
I've been running e85(oft) for about 15k miles and wonder if I should be using any FUEL additives. I've read on other forums that some people use two stroke tc-w3(ashless, burns clean?) and lucas upper cylinder lubricant.
Would those lubes burn clean? Would it help keep things lubed? Is it snake oil? Would they do more harm than good?
Is e85 that much more "dry" than e15 gasoline?
-Off topic- Air oil separator/oil catch can takes out the oil that would otherwise be put into the intake, which is bad? Since engine oil isn't designed to burn(?) or does not burn clean? therefore creating deposits and gunking up the engine?
Old 08-15-2016, 05:25 PM   #2
-Phil
Drives: Rb25 neo brz
I have been running e98 for 2000 Hard track miles and only saw contamination when i had a return style setup with my catch cans. that being said i would keep that in mind with return style systems. As far as lubricants go we have not seen any issues on the valves and everything is running proper.
-Phil is offline   Reply With Quote
Old 08-16-2016, 01:16 PM   #3
kch
Senior Misanthrope
kch's Avatar
Originally Posted by swarb View Post
I've been running e85(oft) for about 15k miles and wonder if I should be using any additives. I've read on other forums that some people use two stroke tc-w3(ashless, burns clean?) and lucas upper cylinder lubricant.
There are only two main concerns with E85 and oil.
1) Make sure the oil is ILSAC GF-5
2) Change the oil a bit more frequently, like every 4-5k
Long Term FR-S regal Scion FR-S / Toyota 86 GT86 General Forum 83 04-01-2016 06:40 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-06-2013 11:58 PM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
