Old 08-14-2016, 03:51 PM   #1
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
Autox Class Help
Not sure which class I'm in for Autox, which mods would I have to remove to run in STX. Currently, I am also unsure if I would be in SM or a street prepared class
Can someone help me clarify?
Exterior
Velox Motorsports Front Splitter
Velox Motorsports Front Endplates
Velox Motorsports Rear Diffuser
HT Auto Side Steps
HT Auto Rear Spats
TRD Canards
TRD Duckbill Wing
SARD LSR Wing
Toyota Badges
JDM Clear Corner Lights
Suspension
Fortune Auto 500 Series Coilovers (7k F, 8k R)
Perrin Front Sway Bar
SPC Rear Lower Control Arms
WRX Rear Sway Bar
Corner Balance and Alignment by Roger Kraus Racing
Engine
Perrin Intake Elbow
HKS Intake Filter
HKS Oil Filter
Gruppe-S Uncatted Unequal Length Header
Brake System
Grimmspeed Master Cylinder Brace
DBA Slotted Rotors
Ferodo DS2500 Brake Pads
Stoptech Stainless Steel Brake Lines
Fluids
Eneos 5w30 Synthetic Engine Oil
Motul RBF600 Brake Fluid
Motul 1L Transmission 300LS Gear Oil
Wheels
XXR 527 17x8
Hankook Ventus RS3 225/40/17
Varrstoenn VT48 Neochrome Lug Nuts
Tuning
Open Flash Table Stage 2 UEL Tune
Miscellaneous
MTEC Drift Shif Knob
Perrin Brake Reservoir Cozy
FT86 Steering Wheel Badge
FT86 Console Insert
Tofurky is offline   Reply With Quote
Old 08-14-2016, 04:00 PM   #2
simpleisbest
Senior Citizen
Drives: Scion FR-S
Exterior
HT Auto Side Steps
HT Auto Rear Spats
TRD Canards
TRD Duckbill Wing
SARD LSR Wing
Toyota Badges
Suspension
WRX Rear Sway Bar
Engine
Perrin Intake Elbow
HKS Intake Filter
HKS Oil Filter
Brake System
DBA Slotted Rotors
Fluids
Wheels
XXR 527 17x8
Tuning
Miscellaneous
FT86 Console Insert
Off the top of my head, to be STX legal, here you go!!
Exterior
Velox Motorsports Front Splitter (REMOVE)
Velox Motorsports Front Endplates (REMOVE)
Velox Motorsports Rear Diffuser (REMOVE)
HT Auto Side Steps (REMOVE)
HT Auto Rear Spats (REMOVE)
TRD Canards (REMOVE)
TRD Duckbill Wing (REMOVE)
SARD LSR Wing (REMOVE)
Toyota Badges
Suspension
SPC Rear Lower Control Arms (Must Replace Spherical Bearings with Bushings: See SCCA Rules)
WRX Rear Sway Bar
Engine
Perrin Intake Elbow
HKS Intake Filter
HKS Oil Filter
Brake System
Grimmspeed Master Cylinder Brace (REMOVE)
DBA Slotted Rotors
Fluids
Wheels
XXR 527 17x8
Tuning
Miscellaneous
FT86 Console Insert
simpleisbest is offline   Reply With Quote
Old 08-14-2016, 04:41 PM   #3
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Right now it looks like you're in SM. Side skirts in any form are not permitted in Street Prepared but there is a provision for splitters. Your canards I'm unsure of but they are permitted in SM. Don't have time to look it all up for you but if you're trying to get down to STX you definitely have some work to do. Fortunately for you the removal (and addition) of badges is permitted in ST__ classes because I know that's the hardest part to change.
Also your JDM corner lights must be reasonably within the same weight of the lights they replaced.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 08-17-2016, 11:28 AM   #4
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Can one swap badges in CS? I haven't swapped mine yet, but was planning to at some point. Don't see anything in the rules about it.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 08-17-2016, 11:42 AM   #5
TrqlessWonder
Drives: 2014 FR-S
it'd be a weenie protest, and wouldn't happen at a local. But, IIDSYCTYC is the official rule.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 08-17-2016, 12:22 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
IIDSYCTYC?
Old 08-17-2016, 12:32 PM   #7
e1_griego
e1_griego's Avatar
Drives: Many
If It Doesn't Say You Can Then You Can't.
IIDSYCTYC
e1_griego is offline   Reply With Quote
Old 08-17-2016, 12:53 PM   #8
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Scion badge it is
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
Old 08-17-2016, 01:39 PM   #9
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
My advice to you:
Since it sounds like you are just getting started autocrossing, I think you should just run in SM with your car the way it is because it's not like you'll be competitive anyway. Compare your times to the STX guys and once your times are competitive for the class, then think about prepping for it.
Lynxis is offline   Reply With Quote
Old 08-17-2016, 03:00 PM   #10
EN2_Squirrel
EN2_Squirrel's Avatar
Originally Posted by Lynxis View Post
My advice to you:
Or just light your wallet on fire and join us in SM. we have cookies, horsepower and purple crack(hoosiers). but yeah avoid good tires until you learn on crap tires. good tires hide mistakes.
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 08-17-2016, 03:11 PM   #11
Locust
Custom User Title
Locust's Avatar
No you cannot.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 08-17-2016, 03:58 PM   #12
e1_griego
e1_griego's Avatar
Drives: Many
The person sweating you for a badge, even at a national event, is a ****.
Old 08-17-2016, 05:05 PM   #13
Locust
Custom User Title
Locust's Avatar
Well if someone debadged their car and took first by 1/1000th would you protest them for the extra 3 ounces of weight savings they got from it? It's a difference of almost $1,500 in contingency money between 1st and 2nd since Scion/TRD only pay out for first place. Why risk it?
Sure if you're going to go and be 50th/80 then whatever, I really doubt 51st-80th are going to protest you. But you go in knowing that you can be.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 08-17-2016, 05:16 PM   #14
e1_griego
e1_griego's Avatar
Drives: Many
3oz of cosmetic shit isn't doing anything for your time.
It will always be a weenie protest.
edit: Since you want to get super duper anal retentive on the rules, the book says "Accessories, gauges, indicators, lights and other appearance, comfort and convenience modifications which have no effect on performance and/or handling and do not materially reduce the weight of the car are permitted."
Materially = substantially, and a badge doesn't constitute any sort of substantial weight.
Debadging would be an easy argument to make.
Maybe somewhere else's it's explicitly prohibited, but I still think a protest for a badge as 1000% weenie protest and the filer of said protest is still a ****.
Aug 1st at Portland Raceway PNW Subaru meet with autox and FR-S/BRZ class stockysnail Northwest 38 08-02-2015 11:24 PM
Quick Autox Video | 2nd in Class Dezoris Tracking / Autocross / HPDE / Drifting 6 04-30-2014 12:23 AM
Quick AutoX class question Thongpocket Tracking / Autocross / HPDE / Drifting 3 02-18-2014 01:38 PM
Anyone for a class? Fuzzysmith Northwest 21 08-13-2012 12:02 PM
autox or autox school? engee Tracking / Autocross / HPDE / Drifting 10 06-12-2012 06:31 PM
