Drives: 2013 FRS
Autox Class Help
Not sure which class I'm in for Autox, which mods would I have to remove to run in STX. Currently, I am also unsure if I would be in SM or a street prepared class
Can someone help me clarify? Exterior Velox Motorsports Front Splitter Velox Motorsports Front Endplates Velox Motorsports Rear Diffuser HT Auto Side Steps HT Auto Rear Spats TRD Canards TRD Duckbill Wing SARD LSR Wing Toyota Badges JDM Clear Corner Lights Suspension Fortune Auto 500 Series Coilovers (7k F, 8k R) Perrin Front Sway Bar SPC Rear Lower Control Arms WRX Rear Sway Bar Corner Balance and Alignment by Roger Kraus Racing Engine Perrin Intake Elbow HKS Intake Filter HKS Oil Filter Gruppe-S Uncatted Unequal Length Header Brake System Grimmspeed Master Cylinder Brace DBA Slotted Rotors Ferodo DS2500 Brake Pads Stoptech Stainless Steel Brake Lines Fluids Eneos 5w30 Synthetic Engine Oil Motul RBF600 Brake Fluid Motul 1L Transmission 300LS Gear Oil Wheels XXR 527 17x8 Hankook Ventus RS3 225/40/17 Varrstoenn VT48 Neochrome Lug Nuts Tuning Open Flash Table Stage 2 UEL Tune Miscellaneous MTEC Drift Shif Knob Perrin Brake Reservoir Cozy FT86 Steering Wheel Badge FT86 Console Insert |
#2 | |
Senior Citizen
Drives: Scion FR-S
Exterior Velox Motorsports Front Splitter (REMOVE) Velox Motorsports Front Endplates (REMOVE) Velox Motorsports Rear Diffuser (REMOVE) HT Auto Side Steps (REMOVE) HT Auto Rear Spats (REMOVE) TRD Canards (REMOVE) TRD Duckbill Wing (REMOVE) SARD LSR Wing (REMOVE) Toyota Badges JDM Clear Corner Lights Suspension Fortune Auto 500 Series Coilovers (7k F, 8k R) Perrin Front Sway Bar SPC Rear Lower Control Arms (Must Replace Spherical Bearings with Bushings: See SCCA Rules) WRX Rear Sway Bar Corner Balance and Alignment by Roger Kraus Racing Engine Perrin Intake Elbow HKS Intake Filter HKS Oil Filter Gruppe-S Uncatted Unequal Length Header Brake System Grimmspeed Master Cylinder Brace (REMOVE) DBA Slotted Rotors Ferodo DS2500 Brake Pads Stoptech Stainless Steel Brake Lines Fluids Eneos 5w30 Synthetic Engine Oil Motul RBF600 Brake Fluid Motul 1L Transmission 300LS Gear Oil Wheels XXR 527 17x8 Hankook Ventus RS3 225/40/17 Varrstoenn VT48 Neochrome Lug Nuts Tuning Open Flash Table Stage 2 UEL Tune Miscellaneous MTEC Drift Shif Knob Perrin Brake Reservoir Cozy FT86 Steering Wheel Badge FT86 Console Insert |
#3 |
Custom User Title
Right now it looks like you're in SM. Side skirts in any form are not permitted in Street Prepared but there is a provision for splitters. Your canards I'm unsure of but they are permitted in SM. Don't have time to look it all up for you but if you're trying to get down to STX you definitely have some work to do. Fortunately for you the removal (and addition) of badges is permitted in ST__ classes because I know that's the hardest part to change.
Also your JDM corner lights must be reasonably within the same weight of the lights they replaced.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#4 |
Drives: '05 Elise
Can one swap badges in CS? I haven't swapped mine yet, but was planning to at some point. Don't see anything in the rules about it.
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
#5 |
Drives: 2014 FR-S
it'd be a weenie protest, and wouldn't happen at a local. But, IIDSYCTYC is the official rule.
-Mike
#24 CS/CSR |
#6 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
IIDSYCTYC?
#7 |
Drives: Many
If It Doesn't Say You Can Then You Can't.
IIDSYCTYC |
#8 |
Drives: '05 Elise
Scion badge it is
'05 Lotus Elise
#9 |
Drives: 2013 WRB BRZ 6MT
My advice to you:
Since it sounds like you are just getting started autocrossing, I think you should just run in SM with your car the way it is because it's not like you'll be competitive anyway. Compare your times to the STX guys and once your times are competitive for the class, then think about prepping for it. |
#10 | |
Or just light your wallet on fire and join us in SM. we have cookies, horsepower and purple crack(hoosiers). but yeah avoid good tires until you learn on crap tires. good tires hide mistakes.
STREET MOD. My wallet now hates me....
#11 |
Custom User Title
No you cannot.
#12 |
Drives: Many
The person sweating you for a badge, even at a national event, is a ****.
#13 | |
Custom User Title
Sure if you're going to go and be 50th/80 then whatever, I really doubt 51st-80th are going to protest you. But you go in knowing that you can be.
#14 |
Drives: Many
3oz of cosmetic shit isn't doing anything for your time.
It will always be a weenie protest. edit: Since you want to get super duper anal retentive on the rules, the book says "Accessories, gauges, indicators, lights and other appearance, comfort and convenience modifications which have no effect on performance and/or handling and do not materially reduce the weight of the car are permitted." Materially = substantially, and a badge doesn't constitute any sort of substantial weight. Debadging would be an easy argument to make. Maybe somewhere else's it's explicitly prohibited, but I still think a protest for a badge as 1000% weenie protest and the filer of said protest is still a ****. Last edited by e1_griego; 08-17-2016 at 07:18 PM. |
| Aug 1st at Portland Raceway PNW Subaru meet with autox and FR-S/BRZ class | stockysnail | Northwest | 38 | 08-02-2015 11:24 PM |
| Quick Autox Video | 2nd in Class | Dezoris | Tracking / Autocross / HPDE / Drifting | 6 | 04-30-2014 12:23 AM |
| Quick AutoX class question | Thongpocket | Tracking / Autocross / HPDE / Drifting | 3 | 02-18-2014 01:38 PM |
| Anyone for a class? | Fuzzysmith | Northwest | 21 | 08-13-2012 12:02 PM |
| autox or autox school? | engee | Tracking / Autocross / HPDE / Drifting | 10 | 06-12-2012 06:31 PM |
