Old 12-12-2014, 06:56 PM   #1
fuzzybat23
fuzzybat23's Avatar
Drives: FR-S Series 10 Release
Electrical Issues
So.. I'm having two electrical issues, thought I'd post here to see if anyone else has had these problems or knows how to fix them.
First is my emblems front and back. They don't light up when I open my car door anymore, either drivers side or passenger. The Scion 10 lights up in the passenger dash still, just not the emblems outside.
The second problem is my power port in the center console. Seems there's an electrical short as anything I have plugged into it will cut on and off whenever I bump the center console with my leg, or hit any bump in the road really.
Any ideas?
fuzzybat23 is offline   Reply With Quote
Old 12-12-2014, 08:51 PM   #2
White64Goat
Warranty work..........
Old 12-12-2014, 08:58 PM   #3
swarb
check fuses.
Old 12-12-2014, 09:36 PM   #4
fatoni
you thought you would post in the vs subforum? just take it to a dealer
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
Tcoat (12-12-2014)
Old 12-12-2014, 09:54 PM   #5
fuzzybat23
fuzzybat23's Avatar
Yeah, I took it to the dealer and the idiot checked the usb port on the radio instead of the power port. He also said he had no idea about the emblems, that he'd have to research it. Anyone know which fuse goes with those, or if they even have a dedicated fuse?
Old 12-12-2014, 10:42 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Check your manual. I believe for the 10 Series, under your drive dash, there is a switch to turn those emblem lights on or off.
Best of luck.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-12-2014, 10:44 PM   #7
fuzzybat23
fuzzybat23's Avatar
Already tried that. There's no switch to turn the emblems on and off. The switch under the dash turns the passenger side dash board light on and off.
Old 12-13-2014, 11:00 AM   #8
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
See if there's anything inside the center console plug. If it's clean you can remove the center console and get to the bottom of the plug pretty quickly. Check out the clutch DIY for the first few steps on how to remove the console, it has great pictures. I'm on my phone or I would link it.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 12-13-2014, 11:13 AM   #9
fuzzybat23
fuzzybat23's Avatar
Yeah, it's not dirty at all. I have one adapter that has an extremely tight fit. I noticed it's led went out when I bumped the center console with my leg. I got it to work once by stuffing water bottles between the console and passenger seat x.x
Old 12-13-2014, 05:27 PM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The FRS Badges is a can of worms that hasn't been opened before. This isn't a common dealership problem as it's only limited to the 2013 year FRS. Assuming you're still under the warranty, I would take it to the dealer.
N1rve
Old 12-13-2014, 05:51 PM   #11
fuzzybat23
fuzzybat23's Avatar
New can of worms is right. I took it to the dealer and even they said they'd have to research the problem.
Weird electrical issues. Need help! Pneub Issues | Warranty | Recalls / TSB 15 09-13-2014 12:38 AM
Electrical system EDCOVEY Issues | Warranty | Recalls / TSB 0 11-26-2012 11:45 PM
Electrical Issues Dr.Science Issues | Warranty | Recalls / TSB 3 11-14-2012 07:18 AM
electrical faults... tibsy92 AUSTRALIA 22 08-19-2012 10:25 PM
FR-S electrical issues... EPIKsung Electronics | Audio | NAV | Infotainment 2 07-23-2012 10:15 PM
