Old 08-08-2016, 02:47 PM   #1
Amputechture
Drives: 2014 BRZ
BOV venting early, any suggestions/ideas?
Hey guys,
Recently installed a JDL turbo kit, having problems with my BOV venting wayyy too early. It seems to be building boost for 1,000 rpms or so...and just as I start getting into the powerband my BOV vents. It feels like being on a boat and the propeller shaft stalls. I have a 3 port boost solenoid that is plumbed as follows:
-Right Side/fitting#1 left alone/vta
-Top fitting/#3 goes to the barb on the cold side of my turbo
-Left side/Fitting #2 going to Lower Air port of Tial MVS wastegate
Vacuum source for the BOV is T'd from the brake booster line. I have confirmed that I am on the correct side of the check valve in the hose.
The wastegate is running a 7 PSI spring, and the BOV was running an 8 PSI spring...I swapped it out to a 12 PSI spring with the same results. I am very concerned at this point because my IAM is extremely low...in the 0.35 neighborhood. My mileage is low and I have never beaten on the car. Is it possible that because of the premature VTA that it could have caused my spark plugs to drastically wear due to exhaust gases not being able to meet the fuel being injected////big rich spikes? Idles like a champ and the low speed driveability is actually pretty good...although I can feel that the car is pulling back timing big time and it feels very sluggish. I am not able to hear any loud knocking or abnormal noises.
Please let me know if you have any suggestions or experience with the same issues I'm seeing. I'm running out of ideas and fear for the health of my car.
Amputechture is offline   Reply With Quote
Old 08-08-2016, 03:11 PM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Are you sure it's the BOV and not the Wastegate? Sounds like a Wastegate issue to me.
DustinS is offline   Reply With Quote
Old 08-09-2016, 07:36 AM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Your tune cares what Springs you have in your BOV & Wastegate. Leave the 7psi WG spring in and install a small yellow in your BOV. The wastegate is the guy on your turbo header and your BOV is on you intake tube.
As of right now your BOV is unable to release pressure, it's to big. You can't just swap either or without tellING your tuner first.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-09-2016, 09:12 AM   #4
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
BOV spring has nothing to do with tune... only thing that effects BOV spring consideration is idle vacuum.
Cockatoo is offline   Reply With Quote
Old 08-09-2016, 09:44 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Amputechture View Post
Hey guys,
Recently installed a JDL turbo kit....
The spring on the BOV is dependent on what is your idle vacuum. You're probably around -19 inHg vacuum so should be using either unpainted or yellow spring (I use the yellow spring). I see you've said you changed to the brown spring with the same results. It seems there is something wrongly installed.
You shouldn't be concerned about early BOV actuation causing any damage since it vents prior to the MAF sensor.
While the car is idling, is the BOV open? Also I'd check the BOV and WG are properly installed and have their O-rings properly installed (I can't remember if both have an O-ring).
Old 08-09-2016, 11:39 AM   #6
Amputechture
Drives: 2014 BRZ
I am on a speed density tune so to my understanding it is not using MAF readings but rather preset values are input in place of the MAF. Before with the 8 PSI spring my BOV was open at idle, now with the 12 it is closed. I am positive that the O-Ring on my BOV is in place correctly, I honestly don't remember either if there was one on the wastegate. In regards to the low IAM, another thing I forgot to mention is that I had what I believe to be a Cam Angle Sensor wire touching my downpipe(which was wrapped). I've since threw a layer of electrical wire and gold foil around the wire that was touching.
Old 08-09-2016, 11:42 AM   #7
Amputechture
Drives: 2014 BRZ
I am currently using the Yellow/7.25 PSI spring in the wastegate. Initially my BOV came preassembled with an 8 PSI spring...JDL told me that due to the fact that it is so far from where it is reading vacuum that it would be fine. I switched to the 12 PSI spring because my tuner initially told me that was what he recommended.
Old 08-09-2016, 11:42 AM   #8
Sportsguy83
Drives: Limited BRZ
Is it 100% on speed density or MAF for drivability and switches over to speed density at higher air velocity?
It's a weird issue for sure, can you clearly hear the BOV? I wonder if you have a boost leak and you are hearing the boost leak at whatever PSI it comes up...
Old 08-09-2016, 12:12 PM   #9
Amputechture
Drives: 2014 BRZ
It is a Delicious F&G, it is advertised as 100% SD....although MAF is one of the parameters he's having me log? The BOV is definitely venting...the sound with the 12 psi spring in now is unmistakable.
I took preemptive measures for boost leaks (clamped the evap hoses in back of the ac compressor, STI PCV Valve).
The Following User Says Thank You to Amputechture For This Useful Post:
Sportsguy83 (08-09-2016)
Old 08-09-2016, 12:30 PM   #10
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Speed density the maf shouldn't even be hooked up. Should be completely unplugged or running a block off plate with the wires going to the intake air temp sensor on the cold side.
Are you running an external waste gate or electronic boost controller ?
If the correct springs were installed I would check EVERWHERE for vacuum lines not being hooked up correctly of backwards. also are you sure it's the bov venting and not the waste gate dumping? Diaphragm in the waste gate could be damage. Like I said if all springs are correct I would check vacuum lines then check waste gate internals for damage.
May be different for your set up but my understand and what I have done in the past the waste gate spring should be set for half the psi of what you are wanting it to dump at so a 7lb Spring would dump at 14 psi
tofurun is offline   Reply With Quote
Old 08-09-2016, 01:00 PM   #11
Amputechture
Drives: 2014 BRZ
I was not aware of this, I just assumed that the MAF readings were ignored. I am using a Tial MVS External/Open Dump WG and a 3 port boost control solenoid. I am out of town at the moment, I plan on going back through everything when I get back. In regards to the O-Ring on the WG...I do remember there being a big orange one that seals the top and bottom half together. Should there be another one?
Old 08-09-2016, 01:07 PM   #12
tofurun
tofurun's Avatar
Just changed an external tial waste gate on a 15 Sti. There was just that orange diaphragm that seal it. If that gets damage it will leak. Also check ur gasket on the bov . If that has a leak it'll sound like blowing air under a loose piece of tape. As long as the tune is set for speed density then there should be no reason for the maf to be hooked up. Backwards vacuum lines can cause extremely high boost and the springs in your waste gate are the only thing saving u from over boosting and going boom.
Old 08-09-2016, 01:10 PM   #13
tofurun
tofurun's Avatar
Really double check that boost controller and make sure the lines are hooked up correctly going to the turbo/intake/and the waste gate.
Old 08-09-2016, 03:35 PM   #14
Sportsguy83
Drives: Limited BRZ
As far as I know, the stock ECU does not do Speed Density, so Ecutek does a workaround for it, and it uses the MAF as a temperature reader as input into the VE calculation. So yes, the MAF is still used, just not as a MAF
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Amputechture (08-09-2016)
Hood Venting, NACA Ducts Lunatic Scion FR-S / Toyota 86 GT86 General Forum 70 02-08-2015 11:10 AM
My insurance story (Venting) Apex-Wolf Scion FR-S / Toyota 86 GT86 General Forum 25 03-19-2014 01:26 PM
Venting - Bad Habits BRZ First-Gen (2012+) — General Topics 25 09-19-2013 03:26 PM
My BRZ is here early... and I'm not ready! Turbowned BRZ First-Gen (2012+) — General Topics 47 06-26-2012 03:10 AM
Car ETA so early? Double4Free Scion FR-S / Toyota 86 GT86 General Forum 32 05-27-2012 10:14 PM
