Old 07-29-2016, 03:50 AM   #1
pepe
Drives: gt86
remove first or second catt?
Hello! it already knows what the catt is important in removing pollution?
it is better decatt headers and retain second catt? or retain OEM headers and eliminate the second catt?
pepe is offline   Reply With Quote
Old 07-29-2016, 05:16 AM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Umm... why?
Old 07-29-2016, 06:07 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
For power, from what I read on this forum, removing the primary cat (in the header) makes a lot more power than removing the secondary cat.
Old 07-29-2016, 07:00 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
But removing 2nd one might be much cheaper/simpler.
Old 07-29-2016, 07:06 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Why not remove both?!
MS, CSCS, TSAC-F, CPT
Old 07-29-2016, 07:10 AM   #6
bfrank1972
Drives: 2013 FR-S Argento
How about aftermarket cats for both?
Sent from my SM-N920V using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 07-29-2016, 07:21 AM   #7
scottman
scottman's Avatar
Drives: 13 mt fr-s
Header one will get you engine codes without a tune.
Second one will be less benefit, but will be cheaper.
I'd say, go header or go home, tho.
scottman is offline   Reply With Quote
Old 07-29-2016, 10:36 AM   #8
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Catless Header + Catless Front Pipe + Tune = 1st for gains = Very Smelly Car
Catless Header + Catted Front Pipe + Tune = 2nd for gains = Car Will Still smell sometimes especially in traffic and on start up, just not as much
Catted Header + Catless Front Pipe + Tune = 3rd for gains = Car won't smell, only on start up while it warms up the cat in header.
Basically the cat in the header is the main cat and most restrictive cat so removing it will create most gains but also create the most smell. Hope that helps you
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 07-29-2016, 10:49 AM   #9
pepe
Drives: gt86
perfect! Thank you very much to all of you
I thought the first cat is there only while the second cat is heated. I thought it was less effective to trap pollution and that the truly important was the second cat cat
Old 07-29-2016, 01:15 PM   #10
stevo585
Drives: White 2014 BRZ
High flow cats are an option too.
I'm catless and I don't notice much smell ever. Its not as strong as say a civic anyways. On e85 there really is no smell.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 07-29-2016, 08:06 PM   #11
Sleepless
Drives: 2016 FR-S
I believe that in most cars, the second cat is there while the first cat is warming up. The secondary cat is less effective and less restrictive. So, as far as solution goes, the first/primary cat does most of the work and is also the most restrictive and thus is the first one most people will remove (via a cat-less header in our cars).
You can definitely tell from the smell when the primary cat is removed (nose-dependent
Sleepless is offline   Reply With Quote
Old 07-29-2016, 09:00 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
When second cat is heated up, it cleans up well enough (many had passed MOT checks if their local rules aren't anal about mods like in CA), even if it's only one. Unfortunately newest smog/exhaust standarts measure also from cold starts, hence extra 1st cat is placed much closer to cylinders, where it happens to be robbing lot of performance, especially for NA. But it heats up to working temps there quicker. From all of this I wouldn't say, that 1st cat does most of work .. it just starts working sooner.
Old 08-01-2016, 01:39 AM   #13
ndreim
ndreim's Avatar
Drives: 2014 wrb brz 6MT
Get a catless header + tune. End of story. Life Changed.
ndreim is offline   Reply With Quote
Which helps in reducing noise, Catt or resonator? deuncos Engine, Exhaust, Transmission 7 03-31-2016 04:41 PM
FI Hood insulation: To remove or not to remove bryan767 Forced Induction 8 08-15-2015 04:51 AM
Best way to remove all this? Kevstra Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 05-11-2014 06:14 PM
please remove samfrs Exterior Parts (Aero, Lighting, Etc.) 0 04-12-2013 07:06 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
