Old 03-30-2016, 02:46 PM   #1
deuncos
Drives: AT Hot lava FRS
Which helps in reducing noise, Catt or resonator?
Which helps more in taming a loud exhaust, having two resonators in the fp or having a catt and a resonator in the fp?
deuncos is offline   Reply With Quote
Old 03-30-2016, 02:47 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=101471
Resonator. By far. Just look at the sound output of Fujitsubo front pipe (resonated) versus Berk front pipe (catted)
-alex
Old 03-30-2016, 02:51 PM   #3
mav1178
mav1178's Avatar
As for other catted + resonated front pipes, I was able to test out the Apex'i one recently.
http://www.ft86club.com/forums/showthread.php?t=103338
W/ only Apex'i front pipe, it was louder than the Fujitsubo front pipe. Fujitsubo was same as stock, Apex'i was about 2db louder.
-alex
Old 03-30-2016, 04:14 PM   #4
deuncos
I just wish the fujitsubo fp wasn't so expensive... I'm considering the HKS dual resonated fp, but i'm wondering if spending more on the fujitsubo piece for the bigger resonators are worth it?
Old 03-30-2016, 08:37 PM   #5
mav1178
mav1178's Avatar
The better question you want to ask yourself is, what is your goal? What exhaust do you want to run? Will you run a cat or is catless an option?
-alex
Old 03-31-2016, 01:30 PM   #6
deuncos
-alex
sorry, I guess I should have started with that. I have the JDL uel catted headers and perrin resonated 2.5in catback, everything else is stock. I'm thinking of getting the JDL overpipe since you can have it ceramic coatted, and also it seems like it doesn't really matter what brand of OP you get in regards to noise. The front pipe is the only thing that's worrying me, majority of the threads I've read all say once you change out your front pipe, the noise increases dramatically especially with header, even if you have a quite catback. My main goal is just having a full 2.5in header back, as well as a little bump in performance (I realize it may not even be noticeable) without having an unbearable exhaust set up.
Old 03-31-2016, 04:22 PM   #7
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
I was full catless with a Tomei 80r... Got the hks dual res is got a little quieter and drone went down a little. But at that noise level loud is just loud.
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
wise345 is offline   Reply With Quote
Old 03-31-2016, 04:41 PM   #8
mav1178
mav1178's Avatar
Depends on the resonator and how it works with the rest of the exhaust.
From my other thread I linked:
Stock exhaust + Apexi header/front pipe: 85.7db
Blitz VS/VSR (quiet exhaust) + Apexi header/front pipe: 84.6db
Same setup w/ Tomei 60R: 106.6db
Same setup w/ Blitz F-Ti (full Titanium one piece exhaust): 102.6db
Ultimately the header isn't as key in sound suppression as the front pipe. The Apex'i header is a 4-2-1 catless design.
-alex
Need helps draining the transmission fluid. BuiRicky Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 02-26-2016 08:40 AM
Evo X vs 14 or 15 STI ...Helps Whitigir Other Vehicles & General Automotive Discussions 10 01-28-2014 02:41 PM
Does the brace bar helps?? or just for look? awang0528 Brakes, Suspension, Chassis 1 03-15-2013 12:06 PM
First 1,000 Mile Review. Hope it helps potential buyers. Saab2Frs Scion FR-S / Toyota 86 GT86 General Forum 20 01-08-2013 03:40 PM
