Old 07-26-2016, 12:11 PM   #1
Maverick986
Drives: 2014 Subaru BRZ
Exhaust Hangers
Hi all! I have not swapped out an exhaust myself before, and have not seen much on this topic. Now that I have a catback on the way I'm curious if I should swap out my hangers?
I have seen multiple products out there, all appear to be polyurethane with different shapes being the most noticeable difference. Is there any manufacturer/style that is better than another? Since I am getting a Perrin catback, should I stick with their hangers too?
Thank you in advance.
Sent from my SM-G925V using Tapatalk
Maverick986 is offline   Reply With Quote
Old 07-26-2016, 12:55 PM   #2
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
The exhaust shop I went to told me the OEM hangers were fine since my car is fairly new yet. I also asked FT86 Hawaii club members and their answer was the same. I love my Perrin catback. Which one did you order? 2.5 or 3.0? resonated or non resonated?
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 07-26-2016, 01:07 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
I have swapped exhaust twice, once after 1 year of owning the car, the second time after 3 years. This car sees winter (with snow and salt) and the exhaust hangers are just fine and poped out easily (with a little WD40). Dont waste your money on unnecessary things.
Old 07-26-2016, 01:10 PM   #4
swarb
Not a big deal. Car is newer so they should still be good. New exhaust should be lighter too. You will know as soon you put them on. Depending on how the hangers sit, there should be tension on the hangers and not on the exhaust flanges.
Old 07-26-2016, 01:11 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Short answer: no.
Long answer: depends on the condition of the stock hangers and whether they are stretched or cracked. Two of mine broke on their own after 30k miles, I bought new ones since it wasn't something I was going to trouble a dealer with.
-alex
Old 07-26-2016, 03:11 PM   #6
Maverick986
Great, that saves ~$50-60. Was not sure if using stock hangers was good enough since the polyurethane ones supposedly keep the exhaust from shifting around more.
Old 07-26-2016, 03:14 PM   #7
Maverick986
2.5" non-resonated. Future plans are to get a nameless long manifold (3") and their over/front pipe (3" front 2" rear gasket/flange).
The Following User Says Thank You to Maverick986 For This Useful Post:
86geek (07-27-2016)
Old 07-26-2016, 03:16 PM   #8
gramicci101
Off Topic
This has been an issue for some people who track their cars hard, but not all. For daily drivers who don't see those kinds of g-forces, it isn't really. Wait to see if it's a problem first, then address it as it comes up.
Old 07-26-2016, 03:42 PM   #9
mav1178
mav1178's Avatar
Usually people buy aftermarket when they realize the stock hangers cost $7 new each (and can still easily break), and aftermarket cost around $10 each and last for a long time.
Plus, the aftermarket poly hangers are mostly meant for older cars in excess of 10 years where the hangers fall apart the moment you take out the exhaust.
-alex
Old 07-26-2016, 04:15 PM   #10
Maverick986
-alex
Good to know, my BRZ is ~2yo, which makes me feel good about not buying any just in case they break/fall apart when taking apart/putting together.
Old 07-27-2016, 10:49 AM   #11
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I had to get new hangers for my Injen exhaust, but that was just because this specific exhaust sits too close to the diffuser with stock-length hangers. You should have no problem.
PandaSPUR is offline   Reply With Quote
Reuse or get new exhaust hangers? Atticus808 DIY (Do-It-Yourself) Guides 5 01-24-2016 06:15 PM
Rubber exhaust hangers JimmyMac Engine, Exhaust, Transmission 20 06-19-2014 12:56 PM
Exhaust Hangers FrSnake Engine, Exhaust, Transmission 11 01-20-2014 01:45 PM
exhaust hangers jazztennor Engine, Exhaust, Transmission 7 02-19-2013 09:57 AM
Exhaust hangers yomchi1989 AUSTRALIA 4 12-01-2012 01:15 AM
