Old 02-18-2013, 01:20 AM   #1
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
exhaust hangers
hey everyone i have changed my exhaust to the evo3 greddy and damn there nice but i need to change the rubber parts on the hangers. Do do you guys recommend??? anything special??
Upgrades
EVO 3 Exhaust,Emblem swap,Full Carbon Interior,Greddy intake
jazztennor is offline   Reply With Quote
Old 02-18-2013, 01:33 AM   #2
whataboutbob
AutoX-10/10ths every run
I replaced mine with some Perrin ones http://www.perrinperformance.com/p/2152. I'm running an Invidia N1 and Invidia front pipe with the high flow cat.
Build thread:Here
Old 02-18-2013, 01:35 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Why you need to replace the stock hangers? They can't be seen unless you go under the car and they do the job since they are so new (unless you broke some )
Nameless, Perrin, they are all very similar if not the same.
Old 02-18-2013, 02:23 AM   #4
Z3D
Taking the stock hangers off can sometimes be a pain. The rubber is sometimes very tight and grabby on the metal hangers. A pro tip is to use an aerosol lubricant like WD40 to aid the rubber hanger mounts coming on and off. Makes life just a bit easier.
Z3D is offline   Reply With Quote
Old 02-18-2013, 03:32 AM   #5
sw20kosh
Drives: 2013 Black FR-S
A pro tip is to buy the clamps that are designed specifically to remove rubber hangers.
Old 02-18-2013, 11:44 AM   #6
jazztennor
jazztennor's Avatar
Drives: Scion FR-s
My exhaust sites funny one side. Next time we are together i will show you one side is lower than the other. So i went under the other day to look. Out of the 4 rubber hangers 3 look perfect but the 4th is not hanging normal. It looks like it has been squished in and it wont move back to a normal stretched position.
Upgrades
The Following User Says Thank You to jazztennor For This Useful Post:
Sportsguy83 (02-18-2013)
Old 02-18-2013, 12:48 PM   #7
jflogerzi
jflogerzi's Avatar
Yup I did this. Also working them in a left to right motion for a bit first will also help make your life easier getting the stock hangers off.
Old 02-19-2013, 09:57 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That sounds like install error. I would loosen everything back up until all the hangers are in a non binded position and then tighten things back up.
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Exhaust hangers yomchi1989 AUSTRALIA 4 12-01-2012 01:15 AM
Rusty exhaust hangers? finch1750 Issues | Warranty | Recalls / TSB 5 11-12-2012 12:29 AM
Can someone explain the diffrence between catback exhaust and axleback exhaust? speedy racer Engine, Exhaust, Transmission 12 09-23-2012 12:24 PM
