Old 01-18-2016, 07:10 PM   #1
Dream20b
Y u do dis?
FA20 with V161 trans
Okay, So i'm going to be building a high 10 or low 11 second Turbo FRS with a closed deck Fa20. After talking with many people, I'm lead to the conclusion that it will be much more reliable to swap a V161 in than try to build an AZ6 to hold 450 RWTQ. Does anyone make a suitable, quality kit for this?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 01-18-2016, 08:06 PM   #2
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
T56 Super Magnum seems to be the best production transmission available for a reasonable amount of money from what I can tell. I've been waiting on someone to come up with a solution for one for the S2000 and 240sx (with SR, not LSx) for a while now. The Getrag V160/161 Supra 6 speed is too expensive and heavy, and although really strong, not bulletproof... The Magnum/Super Magnum is used in the Viper ACR, among others, and is actually supposed to have a really nice shift feel despite being built to hold 700 ft-lb of torque. I want one.
Sideways&Smiling is offline   Reply With Quote
Old 01-18-2016, 10:33 PM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
what does close deck do?/mean? Better compression?
Whats the benefit?
edit: amateur thinking: Better cooling? FA20 does put out a lot of heat, no?
Packofcrows is offline   Reply With Quote
Old 01-19-2016, 08:10 AM   #4
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Whats the benefit?
Pictures are kinda self explanatory. Open deck has better cooling/flow however there is a huge trade-off in strength. Without proper re-sleeving an open deck engine is easily compromised in high horsepower applications, whereas closed deck is superior due to having more meat, slightly less flow means slightly worse cooling powers but theres always a way to cool the engine more efficiently. Theres is no substitute for block strength though.
lukey86 is offline   Reply With Quote
Old 01-19-2016, 02:02 PM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i have an fa20 to tremec tko custom bellhousing for my car. take a look at my build and you should be able to get a decent idea on what to do for a bellhousing. a magnum xl should put the shifter very close to the stock location fyi
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 01-19-2016, 02:16 PM   #6
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
The supra 6 speed would be bulletproof with that power I run over 1000 through mine and it's done great I've seen people not blow them until 1400hp...
T56 would be far more cost effective if they make a good kit to adapt it to the FA20. If they go go with the T56
wise345 is offline   Reply With Quote
Old 01-19-2016, 05:24 PM   #7
brianhj
Drives: 2017 Camaro 1SS
I think it has more to do with how much torque it can handle, as opposed to horsepower, no?
brianhj is offline   Reply With Quote
Old 01-19-2016, 07:07 PM   #8
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Most T56s are probably going to have lousy gear ratios for a high-revving inline 4 in a drag application.
pushrod is offline   Reply With Quote
Old 01-19-2016, 07:57 PM   #9
Dream20b
Y u do dis?
Gearing ratios can always be changed. However, the idea is to have room for "improvement" down the road.
Dat Hot Lava Doe
Old 01-20-2016, 12:26 AM   #10
Sideways&Smiling
Who made it and how much did it cost?
Old 01-21-2016, 06:29 AM   #11
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Dream20b View Post
Okay, So i'm going to be building a high 10 or low 11 second Turbo FRS with a closed deck Fa20. After talking with many people, I'm lead to the conclusion that it will be much more cost effective to swap a T56 in than try to build an AZ6 to hold 450 RWTQ. Does anyone make a suitable, quality kit for this?
Where you getting the closed deck at??
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 01-21-2016, 08:04 AM   #12
Dream20b
Y u do dis?
Heavily leaning on Outfront Motorsports. Editing op to reflect current list of items, T56 not an option. Will be going V161 instead. Better Gearing.
Dat Hot Lava Doe
Old 01-21-2016, 09:28 AM   #13
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
They make a million different ratios for the T56 you know.
Availability and cost alone would make me go to the T56, let alone any other benefit.
You did a pretty good run up from a non intercooled sprintex car, to a full build all of a sudden. Did you win the lottery? If you are dead serious about this there is a lot of research to do before posting a new idea every day in one forum thread.
There are many topics on the supra forums about T56 swaps, might check out some of those.....
Old 01-21-2016, 07:44 PM   #14
Dream20b
Y u do dis?
Well, I was tired of being slow. and its going to be a gradual thing.
Dat Hot Lava Doe
Hollinger Sequential Trans for FA20 extreme-86 Engine, Exhaust, Transmission 38 01-16-2018 04:37 AM
WTB: FA20 and Six Speed Manual Trans Cross Want-To-Buy Requests 2 04-24-2016 12:06 AM
Looking for an FA20, Trans and pieces in AZ Cross Arizona 27 04-03-2015 12:34 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 07:44 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
