Old 07-11-2016, 05:56 PM   #1
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Timing chain service
I'm looking through the manual, and I'm wondering what's the mileage that requires replacing the timing chain and doing all that mess? Someone I know thinks it is 100K but I want to know details. Thanks.
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 07-11-2016, 06:08 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
There isn't a scheduled service for the timing chain. They should last the life of the motor.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-11-2016, 06:10 PM   #3
ChuckD
Drives: 2013 FRS M6
Like Apoc said there typically are no service times for timing chain. Timing belts are a different matter though. They typically get serviced like every 60 to 100k miles depending on engine and manufacturer.
ChuckD is offline   Reply With Quote
Old 07-11-2016, 06:21 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The service interval is never, unless you somehow stretch the chain.
Old 07-12-2016, 08:31 AM   #5
OkieSnuffBox
Drives: '23 BRZ Limited
A rod will say peekaboo before you need to replace the timing chain.
Old 07-12-2016, 10:49 AM   #6
radroach
Drives: car
I've read about Fords and Audis that needed timing chain work. Guessing the timing chain stretching is more of an issue for engines that handle higher loads? Or is it just materials quality?
Old 07-12-2016, 11:04 AM   #7
OkieSnuffBox
Design specifications.
Old 07-12-2016, 11:17 AM   #8
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Some vehicles have issues with chain tensioners, but rarely with the actual chains.
I remember a service manager at a Toyota dealer trying to convince me to have my belts replaced in my Celica GTS.
I asked him, "Belts in the 2ZZGE engine?" He said "Yes, those have a 60,000 mile replacement interval".
Got a deer in the headlights look when I took the keys back and informed him that I didn't appreciate being sold belt service for a vehicle with timing chains.
I left and never went back to that service department.
Shinigami301 is offline   Reply With Quote
Old 07-12-2016, 01:02 PM   #9
mav1178
mav1178's Avatar
A little bit of both.
Chains stretch over time with normal use, as is the case with most metals that see lateral loads. It's kind of dumb to overhaul a high mileage engine and not do timing chain while you are at it.
There's some obscure info about design specs, but generally you will want to replace timing chain if it's stretched to the point where camshaft timing is off by an amount that cannot be corrected by the cam gears.
In general, timing chain systems usually have the chain tensioner replaced first before the chain is serviced.
Source: many many years of KA/SR experience.
-alex
Old 07-12-2016, 03:36 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
I had this conversation with a friend recently. Not stretch, but wear. (I know, BFD)
I'm just putting this out there for all interested. Worn chains wear sprockets. Worn sprockets wear chains. Always replace them as a complete set.
Another way to identify wear is by wrapping the chain around the cam sprocket. Then try to lift the chain away from the sprocket while it's on there. If there's any give, it's worn. A new chain and sprocket will match up perfectly.
Old 07-12-2016, 09:03 PM   #11
mav1178
mav1178's Avatar
Originally Posted by tCsonfrs View Post
That car still had belt(s) for accessories, good job on looking like as ass.
http://www.newcelica.org/forums/showthread.php?t=325398
Old 07-13-2016, 10:51 AM   #12
Shinigami301
He was referring to timing belts. Specifically.
Your insult is misguided and most unwelcome.
Old 07-13-2016, 11:40 AM   #13
strat61caster
strat61caster's Avatar
Went and replaced the timing chain in my KA24DE with 200k miles of beating over ~23 years. It was totally unnecessary and I made a few mistakes doing the job which means I wish I hadn't even bothered, the problem I was trying to resolve had a simpler solution.
ineedyourdiddly
Old 07-13-2016, 11:40 AM   #14
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Someone assumed... I LOL'd
Subaru STI :
Oil leak - timing chain cover CB762 Issues | Warranty | Recalls / TSB 3 08-24-2016 04:45 PM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
setting timing after chain removal? joer33 Engine, Exhaust, Transmission 0 10-06-2015 01:39 PM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
Timing Chain Cover Replacement - Need Advice Gen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-02-2014 12:15 PM
