Old 10-06-2015, 01:39 PM   #1
joer33
Drives: 2013 limited brz, skyline R33 gtst
setting timing after chain removal?
Hey guys, a friend bought a 2013 limited brz that has been in an accident. Long story short the motor needed some work and he took the timing chain plate off, took the right side chain off and rotated the cams without marking or anything. Im new to boxer motors. Is there a walkthrough i can follow to get this thing back to tdc and timed? Where the marks are, which piston is #1 etc. Any info appreciated.
Thanks guys.
joer33 is offline   Reply With Quote
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
WTB front timing chain plate & LH cam cradle (?) joer33 Want-To-Buy Requests 0 09-19-2015 10:42 AM
TSB for P1604 with no CEL; Startability Malfunction/Timing Chain Cover replacement Hector Issues | Warranty | Recalls / TSB 1 03-01-2015 08:01 PM
Timing Chain Cover Replacement - Need Advice Gen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-02-2014 12:15 PM
