Old 03-18-2014, 01:16 PM   #1
Gen
Drives: Scion FR-S
Timing Chain Cover Replacement - Need Advice
Gen is offline   Reply With Quote
Old 03-18-2014, 02:31 PM   #2
FullBlown
FullBlown's Avatar
Drives: Scion FRS
What's up with all the sludge? Those look like rough machine marks. It looks like an oil galley block off plate. If you are concerned, block sand it with some 600 grit wet sand paper and you should be good.
FullBlown is offline   Reply With Quote
Old 03-18-2014, 02:49 PM   #3
Gen
Drives: Scion FR-S
Lot of silicone apparently... thanks for the response!
Old 04-02-2014, 12:07 PM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
was shop #1 fa20club? it literally looks like their quality of workmanship. If so, im surprised you got the car back in one piece.
supramkivtt2jz is offline   Reply With Quote
Old 04-02-2014, 12:15 PM   #5
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
I would be more concerned about the debris in the oil galley of your oil pump cover. If that was my motor I would roll it over and take a peak at the rod bearings which is very easy on the FA motor.
The silicone is what seals the front cover so it should not be an issue if its cleaned and re-siliconed properly.
Crawford Performance is offline   Reply With Quote
Low car + replacement axles + raising diff advice JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 04-05-2019 08:47 PM
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-10-2016 11:25 PM
86 key chain (Scion FR-S) dcfr Canada Classifieds 11 08-26-2014 11:35 AM
Car Towed and Bumper cover scratched. Need advice. JoeCFRS Issues | Warranty | Recalls / TSB 18 09-10-2013 05:27 PM
A new DRL option (Fog cover replacement) SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 5 01-18-2013 12:15 AM
